Rev Limiter Problem
Old Mar 6, 2005 | 05:02 PM
hbvetteslayer's Avatar
Default Rev Limiter Problem
Ok, I have a 98 sh with an act xact flywheel and act ss clutch/ pressure plate. If i'm pushing it and i get the tach up to 6500 in 1st, 2nd, or 3rd (i have not tried it in 4th or 5th) the rev limiter kicks in and wont let me past 6500. I talked to a couple local shops they have no clue and the honda dealer wants $95 an hour to figure it out so i'm tring to avoid that. Has anyone had this problam?
Thanks
Old Mar 6, 2005 | 05:38 PM
A Blue Lude's Avatar
Default Re: Rev Limiter Problem (hbvetteslayer)
Are you throwing a CEL? A lowered rev limit means that the ECU's running in safe mode.
Old Mar 6, 2005 | 07:20 PM
Goinfasterthanu's Avatar
make shure your oil is full .....you have no vtec
Old Mar 7, 2005 | 04:34 AM
kulrevon's Avatar
Default Re: (Goinfasterthanu)
was your car warmed up to operating tamp. is your vtec water temp sensor working? do you have oil pressure . is your vtec solonoid operating vtec.
Old Mar 7, 2005 | 06:58 AM
UA6 BALLER STATUS's Avatar
Is your car cold when you ran it? check the temp gauges, cuz when its cold it wont let you go past 6500.
Old Mar 7, 2005 | 07:22 PM
Gerhard_001's Avatar
Any CEl's? here is what a honda motor needs to engage VTEC
1. 160C temp
2. Speed
3. VTEC
4. oil pressure
5. RPM
Old Mar 7, 2005 | 07:30 PM
The Phil's Avatar
Default Re: Rev Limiter Problem (Gerhard_001)
Most CELs bump it into limp mode, which means no VTEC, 6500rpm rev limit.
Old Mar 8, 2005 | 04:09 PM
Default Re: Rev Limiter Problem (xthephilx)
well the car is definitly warmed up. and i definitly have oil it is full all the way up to the the top line and i have checked it like 5 times over the last couple days because thats what everyone says but i definitly have oil. and it seems like the vtec is kicking in but half way threw it cuts out How do i go about checking to see if i am throwing a CEL ?
Old Mar 8, 2005 | 08:28 PM
JDMF22B's Avatar
a check engine light would pop up on ur dashboard *slaps head*
Old Mar 8, 2005 | 08:58 PM
matix's Avatar
Default Re: Rev Limiter Problem (JDMF22B)
if you have no engine light at all i would check the vtec solenoid itself.
Old Mar 8, 2005 | 09:40 PM
SKDRCR's Avatar
Default Re: Rev Limiter Problem (matix)
read this thread as well
https://honda-tech.com/zerothread?id=830163
Old Mar 9, 2005 | 02:17 PM
Default Re: Rev Limiter Problem (SKDRCR)
Thanks for the link and all the other help once i figure this out ill post the problem
hondarazor23
Jan 29, 2009 07:53 PM
soloteg2
Apr 9, 2006 10:58 AM
salman
Mar 14, 2005 12:43 AM
Import RP
Sep 25, 2003 06:58 PM
itr501
Jun 25, 2001 10:06 PM
