how to remove carbon deposits off the tops of pistons while in the car
Old Jan 22, 2002 | 01:08 AM
Babybluegsr92's Avatar
Default how to remove carbon deposits off the tops of pistons while in the car
I recently removed my cylinder head so i could have the valve fixed while its at the machine shop i notice some carbon on the tops of the pistons should i remove this? what is the best way to remove it? while the pistons are in the block? what chemcial? or should i just leave it alone?
-Thanks
-joe
Old Jan 22, 2002 | 05:08 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: how to remove carbon deposits off the tops of pistons while in the car (Babybluegsr92)
soft brass wire brush head in a angle grinder at 40-45 psi.
Old Jan 22, 2002 | 09:31 AM
GTEater's Avatar
Default Re: how to remove carbon deposits off the tops of pistons while in the car (Mista Bone)
carb cleaner?
Old Jan 22, 2002 | 09:36 AM
Jesse H's Avatar
Default Re: how to remove carbon deposits off the tops of pistons while in the car (GTEater)
automatic transmission fluid works good.
ringgold
Engine Machining & Assembly
May 27, 2019 01:39 PM
lude98SH
Jul 31, 2007 12:50 PM
EK FLY
Jan 31, 2006 05:42 PM
b16 matt
Sep 26, 2004 05:15 PM
KayOs
Oct 4, 2001 10:12 PM
