timing belt was coming off so I pulled the cover and the tensioner bolt was broke???
Old Mar 6, 2005 | 04:05 PM
kholmes's Avatar
Default timing belt was coming off so I pulled the cover and the tensioner bolt was broke???
I have a h22a, a cam gear was bent and the belt was working its way off so I replaced the gear thinking that was the prob and the new timing belt still was trying to come off. The timing belt cover shaved a quarter of the belt off in a day. I pulled the cover off and the bolt that holds the tensioner pulley on tight was broken off. Everything looks fine so Im stumped, any suggestions?
Old Mar 6, 2005 | 04:40 PM
TxTuner
Guest
Posts: n/a
Default Re: timing belt was coming off so I pulled the cover and the tensioner bolt was broke??? (kholmes)
it's simple really.... REPLACE THE BOLT!!!
Old Mar 6, 2005 | 05:39 PM
kholmes's Avatar
Default Re: timing belt was coming off so I pulled the cover and the tensioner bolt was broke??? (TxTuner)
Hey, thats great! so it can brake again! Good idea. Im trying to figure out why it broke in the first place.
Old Mar 6, 2005 | 07:19 PM
H22SRV's Avatar
Hey what setup are you running?? Stock tensioner components or did you do a H23 conversion.
Old Mar 6, 2005 | 09:00 PM
connvict's Avatar
All you can do is replace the bolt.
The same exact thing happened to me about a year ago, almost lost the engine the belt was shredded and gone so bad.
Anyway, just replace the bolt, i don't know why it happened to me either, but I haven't had any problems since.......
Old Mar 6, 2005 | 09:24 PM
kholmes's Avatar
Default Re: (connvict)
Its a stock auto tensioner.
Yeah, Im gonna replace the bolt and put it together without the cover and watch it run for a while to see if theres a problem.
Old Mar 9, 2005 | 11:24 PM
edulerp97's Avatar
Default Re: (kholmes)
My tensioner broke on my h22a4 Because of my Stage 2 cam Thenl I did a h23 manuel tensioner conversion and have not had a problem since then.....
Old Feb 19, 2025 | 02:37 PM
xchino's Avatar
Icon5 Re: timing belt was coming off so I pulled the cover and the tensioner bolt was broke
I don't know if I'll get a response but I have an h22a4 and just upgraded the head. Stage 2 tuner cams, alpha spring & retainer, and tuner cam gears. when I cranked the car it ran awesome! about 2 months later I noticed that my belt was slowly getting chewed by my valve cover(BELT WALK). I replaced my belt and added a manual tensioner. I had my mechanic review my timing and when I got my car back it ran fine for about a week. Now I have the timing belt whining and I see the belt once again getting chewed by something. Im at a lose. I don't know where to go from here
Old Mar 16, 2025 | 10:58 PM
Sakanora's Avatar
Sounds like something is not running true. Might be your cam-gears are warped since this didn't start until you modified the head. Can you use the OEM ones with your new cams?
LI-HONDAGUY
Honda Civic (2001 - 2005)
Dec 28, 2018 04:30 PM
Jimster480
Nov 11, 2010 08:04 AM
methos713
May 5, 2008 08:01 PM
JDN169
Nov 7, 2006 07:49 AM
BACKintheDA
Sep 19, 2004 03:26 PM
