1/4 Times with Neukin and Hondata
Old Mar 6, 2005 | 02:15 PM
nsxmatt's Avatar
Default 1/4 Times with Neukin and Hondata
Went to opening day to do some shakedown passes on the new Neukin manifold and Hondata.
Setup:
92 Civic VX
Full interior
Bone stock B16
Stock Tranny
Stock ITR Clutch (starting to slip)
Stock Axles
Hondata s200b
RC 750's
Neukin Manifold/3 inch DP
Turbonetics t3/t04
Ran two 11.7's before the track got very crowded so we left. Was run on small 22x8 slicks and car was driven 120 miles each way to the track.
Can't wait till I get it fully tuned and put the 24's on with some more boost
Old Mar 6, 2005 | 02:40 PM
hondaguyef's Avatar
Default Re: 1/4 Times with Neukin and Hondata (nsxmatt)
Matt. I have always been impressed by your car. Let see those 24.5 times soon
Phil
Old Mar 6, 2005 | 03:16 PM
nsxmatt's Avatar
Thanks! Should be soon if I get a clutch in
Old Mar 6, 2005 | 03:34 PM
Kwuaymaikrup's Avatar
What was the MPH hour? I am also curious to what kind of power you are making and the weight....nice times
Old Mar 6, 2005 | 03:48 PM
nsxmatt's Avatar
Default Re: 1/4 Times with Neukin and Hondata (Kwuaymaikrup)
The car weighs about 2200lbs or so with me in it now. I took off the CF hood and didn't remove any of the interior this time. The MPH was better but I don't want to post it yet
Old Mar 6, 2005 | 04:44 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote"> The MPH was better but I don't want to post it yet </TD></TR></TABLE>
May I take a guess? 121mph.?(You can PM me wether or not I am correct ).
Old Mar 6, 2005 | 04:58 PM
ctap's Avatar
Default Re: 1/4 Times with Neukin and Hondata (hondaguyef)
nice times
Old Mar 6, 2005 | 05:08 PM
D-tuned's Avatar
Default Re: 1/4 Times with Neukin and Hondata (ctap)
good times
Old Mar 7, 2005 | 07:30 AM
DATZ WEAKSAUCE's Avatar
Default Re: 1/4 Times with Neukin and Hondata (2000civicsi)
11.7 stock b16 on boost
Old Mar 7, 2005 | 08:59 AM
seen4ever's Avatar
Default Re: 1/4 Times with Neukin and Hondata (DATZ WEAKSAUCE)
how much boost? if you say 8psi then i may go ahead and just sell my car now. I was amazed how good it pulled at 8psi in high cam, can't wait to see what will happen once the tune can get a little cleaner.
Old Mar 7, 2005 | 09:28 AM
turbo*s2k's Avatar
Default Re: 1/4 Times with Neukin and Hondata (seen4ever)
nice!
Old Mar 7, 2005 | 09:51 AM
Evill Supra's Avatar
Default Re: 1/4 Times with Neukin and Hondata (TurboChrgd_Civic)
He can run less boost and make good power because he has a higher static compression ratio then those guys with "built" motors that have lower compression pistons. Makes sense to me.
BTW-nice run Matt.
Steve K.
Old Mar 7, 2005 | 10:12 AM
seen4ever's Avatar
Default Re: 1/4 Times with Neukin and Hondata (Evill Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evill Supra &raquo;</TD></TR><TR><TD CLASS="quote">He can run less boost and make good power because he has a higher static compression ratio then those guys with "built" motors that have lower compression pistons. Makes sense to me.
BTW-nice run Matt.
Steve K.</TD></TR></TABLE>
i was just wondering, because he ran 11.8s last year with his drag kit at 11psi, just wondering if he was running less boost now to run faster than what he did last year.
Old Mar 7, 2005 | 12:36 PM
gitwidit's Avatar
Nice work Matt! Can't wait to see it in action again!
Old Mar 7, 2005 | 12:57 PM
Rod.'s Avatar
Default Re: 1/4 Times with Neukin and Hondata (GITWIDIT)
I just want to know how much boost ? When do you see full boost on the neukin over the drag manifold?
Old Mar 7, 2005 | 01:17 PM
nsxmatt's Avatar
According to the Hondata logs, 10psi. It spools about 400rpm sooner than the drag and just feels better too.
Old Mar 7, 2005 | 05:49 PM
Neukin's Avatar
Default Re: (nsxmatt)
Thats great to hear. Just dont blow that honda yo. hehe
Old Mar 8, 2005 | 04:17 PM
Turbocivic94's Avatar
nice times
Old Mar 8, 2005 | 06:59 PM
T4eg's Avatar
Default Re: (Turbocivic94)
very impressive....congrats.
Chris
Old Mar 10, 2005 | 02:31 AM
jonyb's Avatar
Default Re: (BlueHatch00)
to Matt
Old Mar 10, 2005 | 06:45 AM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Thanks! Should be soon if I get a clutch in </TD></TR></TABLE>
Good luck Matt!!!
Just be careful on those 24.5 if you are still using the stock axles with that long ride home!!!!Just stop at auto zone and pick up some $50 axles in case you break one..
Old Mar 10, 2005 | 02:22 PM
STREETWERKZ's Avatar
Default Re: (99lspwr)
**** that, im going TURBO!!!
still havent installed my fogger system on my B16.
maybe B16 turbo nitrous!?
Old Mar 10, 2005 | 04:51 PM
tkHBseries's Avatar
Default Re: (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">**** that, im going TURBO!!!
maybe B16 turbo nitrous!? </TD></TR></TABLE>
Why dont you install the nos kit and give it a run....dude! N20 imo is badass and less of a headache than turbo! Dedicated Squeezer! Im pretty sure you should be in the mid to low 13's....then work off of that!
Old Mar 10, 2005 | 05:32 PM
Default Re: (tkHBseries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkHBseries &raquo;</TD></TR><TR><TD CLASS="quote">
Why dont you install the nos kit and give it a run....dude! N20 imo is badass and less of a headache than turbo! Dedicated Squeezer! Im pretty sure you should be in the mid to low 13's....then work off of that!</TD></TR></TABLE>
already ran a 13.4 on a stock internal B16 NA.
b20vcrxsir
Dec 28, 2016 05:31 PM
viney
May 18, 2004 04:59 AM
Elite Hatch
Aug 25, 2002 01:37 PM
JMinSi2000
May 24, 2002 11:34 PM
Aeka GSR
May 10, 2002 09:12 AM
