Quick question regarding all the piping!!
Old Jan 21, 2002 | 10:38 PM
JDM_Type-R's Avatar
Default Quick question regarding all the piping!!
Hi, i was just wondering what all the pipes are that are between the muffler and the header. How many different pipes are there? And which pipes does the Spoon N1 come with? Would this setup work? Spoon 4-2-1 Headers, Carsound Cat, Spoon N1? Are there any aftermarket products that will fit between the carsound cat and the spoon n1 for better flow? Any info appreciated. thanks.
Old Jan 21, 2002 | 10:42 PM
yellow blur's Avatar
Default Re: Quick question regarding all the piping!! (JDM_Type-R)
i think the type-one b-pipe was supposed to fit between the cat and the n1 muffler. correct me if im wrong.
Old Jan 22, 2002 | 12:12 AM
AJ PwR's Avatar
If you are not running into emissions so why you want to run a cat ? I think you should run a test-pipe with TypeONE B-pipe with Spoon N1. You will be happy with that power. If you are afraid it might get too loud then put in the silencer.
Old Jan 22, 2002 | 02:19 PM
JDM_Type-R's Avatar
Default Re: Quick question regarding all the piping!! (AJ PwR)
Why do you recommend the TYPE ONE over the Spoon 4-2-1? I heard the quality and performance were both good, but not quite as good as the Spoon 4-2-1. Also, don't test pipes tend to smell ?
Old Jan 22, 2002 | 03:44 PM
B2FiNiTY's Avatar
He's saying the b-pipe. It's 2.5 piping all the way through. I'll be getting a spoon sport with a type-one b-pipe. Test pipes will probably make your exhaust smell like rotten eggs.
[Modified by B2FiNiTY, 4:44 PM 1/22/2002]
Old Jan 22, 2002 | 10:17 PM
JDM_Type-R's Avatar
Default Re: Quick question regarding all the piping!! (B2FiNiTY)
So would you still need the CarSound Cat if you were to get the Type One B-pipe? im sorta confused...
Old Jan 22, 2002 | 10:30 PM
B2FiNiTY's Avatar
Ok...
Cat is for the Header. 2.5inch
Typeone B-pipe is basically a less restrictive version of the stock one.
Old Jan 23, 2002 | 12:02 AM
Gump's Avatar
where can you get the type one b pipe?
JDMDC4life
Nov 22, 2006 05:54 AM
xla301
Mar 11, 2005 01:08 PM
rafael_dias
28
Dec 1, 2004 06:14 PM
SpoonSiR2
10
Mar 12, 2002 07:29 AM
