I CHANGED A HEADGASKET ON A SOHC AND NOW ITS...HELP
A FRIEND OF MINE CHANGED HIS SOHC HEADGASKET AND NOW ITS SMOKING WHITE..THE HEADGASKET WONT FIT BUT ONLY ONE WAY ON THE MOTOR...NOW THE MOTOR IS SMOKING WHITE SMOKE AND KINDA SMELLS SWEET LIKE COOLANT BUT COULD IT BE???HELP ME
Uh, thats cause its burning coolant. Did you properly torque the new one? Was it damaged in any way? Regardless, the one on there now isnt installed properly and will need to be repaired/replaced.
I DIDNT TORQUE THE NEW HEADGASKET ON I JUST TIGHTENED IT... SHOULD I TAKE IT BACK APART? IT WASNT DAMAGED AND IT WOULDNT FIT ON THE BLOCK ANYWAY BUT THAT WAY..
First step to torque is 22ft/lbs and the second step is 53 ft/lb for d16s and 47ft/lb for d15s. This all must be done in sequence..Starting with...
1) bottom center
2) Top center
3) next bolt left bottom
4) next bolt to the right of the center top
5) next bolt to the right bottom
6) next bolt to the left of the center top
7) last bolt to thr right bottom
8) last bolt to the left top
9) last bolt to the left bottom
10)last bolt to the right top
1) bottom center
2) Top center
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">whats the torque specs?????</TD></TR></TABLE>
look at the post above me.........he beat me to it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian »</TD></TR><TR><TD CLASS="quote">First step to torque is 22ft/lbs and the second step is 53 ft/lb for d16s and 47ft/lb for d15s. This all must be done in sequence..Starting with...
1) bottom center
2) Top center
10)last bolt to the right top</TD></TR></TABLE>
you missed a step.
11) don't post in all caps
1) bottom center
2) Top center
you missed a step.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh »</TD></TR><TR><TD CLASS="quote">I DIDNT TORQUE THE NEW HEADGASKET ON I JUST TIGHTENED IT..</TD></TR></TABLE>
LMAO!!!!!!
LMAO!!!!!!
make sure you clean the mating surfaces when you put it back togethor or you can get little particles stuck between the surfaces or gasket. happened to me one time it sucked. just wipe it off really good.
