TYPE R TRANS fluid change.....
Old Mar 6, 2005 | 06:35 AM
1bad16v's Avatar
Default TYPE R TRANS fluid change.....
how many quarts of oil and what weight???? any help would be awesome
thanks
Old Mar 6, 2005 | 06:40 AM
1999all_motoR_teg's Avatar
Default Re: TYPE R TRANS fluid change..... (1bad16v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad16v &raquo;</TD></TR><TR><TD CLASS="quote">how many quarts of oil and what weight???? any help would be awesome
thanks </TD></TR></TABLE>
Honda MTF and it's about 2.3 quarts according to the Helms manaul. If you searched you would have found the answer very easily.
Old Mar 6, 2005 | 06:43 AM
jdmitr's Avatar
Usually almost 2 1/2 quarts. Drain the tranny, but the plug back with a new crush washer. Then make sure your car is pretty level, and put in about 2 1/2 quarts, and if it does not start draining out the fill hole then you need to add a little more! It is full when the fluid is level with the bottom of the fill hole.
I only use eithter Honda MTF or Kaaz!!!
Old Mar 6, 2005 | 07:00 AM
Bbasso's Avatar
Default Re: TYPE R TRANS fluid change..... (1999all_motoR_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF and it's about 2.3 quarts according to the Helms manaul. If you searched you would have found the answer very easily.</TD></TR></TABLE>
perfect answer, not 2 1/2
And the car has to be level as possible- don't skimp out on filling it, there is a reason why Honda said 2.3
Old Mar 6, 2005 | 07:02 AM
1bad16v's Avatar
thanks alot im on me way to honda to get the stuff...
Old Mar 6, 2005 | 07:06 AM
Bbasso's Avatar
Default Re: (1bad16v)
Make sure you get a new crush washer from the dealer
Old Mar 6, 2005 | 07:16 AM
baonest's Avatar
Default Re: (Bbasso)
bahhhhhhhhhhh thats one thing i forgot. the damn washer. well looks like the tranny fluid change will have to wait
Old Mar 6, 2005 | 12:47 PM
1GreyTeg's Avatar
Default Re: (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">bahhhhhhhhhhh thats one thing i forgot. the damn washer. well looks like the tranny fluid change will have to wait</TD></TR></TABLE>
There are two different washers. The smaller of the two is the same as the oil pan fyi.
And here's a good post that follows up on this all, strangely enough we can credit OPIE?!
https://honda-tech.com/zerothread?id=641356
And a link to a step by step:
http://www.c-speedracing.com/h...d.php
Btw, it's very easy. If I can do it so can a lame, blind and thick headed monkey.
Old Mar 6, 2005 | 02:47 PM
warwagon's Avatar
i must hop in and reccomend gm syncromesh tranny fluid.... it is currently prolonging my tranyy rebuild
Old Mar 6, 2005 | 04:31 PM
Dr Pooface's Avatar
You can reuse the washer.
Old Mar 6, 2005 | 04:35 PM
baonest's Avatar
Default Re: (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
You can reuse the washer. </TD></TR></TABLE> this is the first tranny fluid change im doing since i bought the car. it has about 120XXX miles on it. not sure when the last time the previous owner changed it. might as well get a washer from honda.
Old Mar 6, 2005 | 04:39 PM
DC2IntegraTypeR's Avatar
Default Re: (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">i must hop in and reccomend gm syncromesh tranny fluid.... it is currently prolonging my tranyy rebuild</TD></TR></TABLE>
I've used GM syncromesh 2 tranny fluid changes ago. I must say...it can't beat MTF in terms of smoothness. IT got pretty crappy after only 5k miles and kept making me grind. Honda MTF =
Old Mar 6, 2005 | 08:07 PM
warwagon's Avatar
Default Re: (RisforTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RisforTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
I've used GM syncromesh 2 tranny fluid changes ago. I must say...it can't beat MTF in terms of smoothness. IT got pretty crappy after only 5k miles and kept making me grind. Honda MTF = </TD></TR></TABLE>
well it took my grind from 5k to around 8k and that has been about 2000 miles ago.... we'll find out how long it holds up
Old Mar 6, 2005 | 08:32 PM
B2FiNiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RisforTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I've used GM syncromesh 2 tranny fluid changes ago. I must say...it can't beat MTF in terms of smoothness. IT got pretty crappy after only 5k miles and kept making me grind. Honda MTF = </TD></TR></TABLE>
DOod. You have to use friction modified. That is what is the good stuff.
Old Mar 6, 2005 | 08:59 PM
Good ol' Screwtape's Avatar
Multi-paradigm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad16v &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot im on me way to honda to get the stuff...</TD></TR></TABLE>
yep Honda MTF
Old Mar 7, 2005 | 06:35 AM
fqnjdmboy's Avatar
Thank god someone brought up GM syncromesh...It works wonders!
Old Mar 7, 2005 | 06:46 AM
.RJ's Avatar
.RJ
Default Re: (fqnjdmboy)
motul
Old Mar 7, 2005 | 06:51 AM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">You can reuse the washer. </TD></TR></TABLE>
Not recommended, because it's a crush washer... once used it's crushed and possibly won't seal right again.
Old Mar 7, 2005 | 07:11 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">once used it's crushed and possibly won't seal right again.</TD></TR></TABLE>
I have never replaced one and never had a problem.
Old Mar 7, 2005 | 07:15 AM
Bbasso's Avatar
Default Re: (.RJ)
Luck= You.
no luck= Me.
Old Mar 7, 2005 | 07:16 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">no luck= Me.</TD></TR></TABLE>
ha ha &lt;/nelson&gt;
Old Mar 7, 2005 | 07:32 AM
RTW DC2R's Avatar
been using GM Synchromesh (not friction modified) for the last 20K miles, no problems getting into 1st/3rd like I had with the MTF. I never replaced the crush washer either. :shrugs:
honda-guy72
32
Sep 21, 2008 09:54 PM
singher01
Jul 25, 2008 10:19 AM
dc5 kid
12
Nov 2, 2007 12:17 PM
j.star
Jul 14, 2007 05:06 PM
lsvtec101
Honda Civic (2006 - 2015)
23
Jun 22, 2007 01:57 PM
