b16 swap help!!!!
we got the swap in and it runs and everything......but i was wondering what lower and top radiator hose do i use for this?i have 1993 civic si.....swapped a b16....what throttle cable should i get? should i go ahead and get the TPS from the honda dealership or go somewhere like napa? thanx for help!
you can use del sol b16 hoses or 99-00 si hoses, should fit. you can get the throttle cable you need here http://inlinefour.com/oemintypthro.html
use the stock throttle cable in your car... just buy the adapter to move the old throttle cable bracket closer to the throttle body on the b16. Use the 94-95 dohc vtec del sol upper and lower hoses and dont forget to buy the clamps to go with them...the old ones on your si are a tad smaller.
you cant get the tps from the dealer....you would have to buy the whole throttle body...just look for one at your local junkyard...any integra DA or DC should work, just needs minor adjustment...(search ht). good luck
runitup
Nov 27, 2003 12:16 PM
2camsaam
Sep 12, 2003 08:20 PM
