Engine Stalls
Old Mar 5, 2005 | 05:58 PM
ttracing03's Avatar
Default Engine Stalls
Wondering if anyone can help???? I have a 96 Ex with a B16 installed. Recently it has been stalling when I come to a stop? I added fuel injector cleaner and replaced my fuel filter, but it still cuts out. Anyone with this swap ever had the same problem?
Old Mar 6, 2005 | 08:51 AM
hatchi's Avatar
Default Re: Engine Stalls (ttracing03)
did you check timing?? has it always done that??
Old Mar 6, 2005 | 02:49 PM
ttracing03's Avatar
Default Re: Engine Stalls (hatchi)
It has just started doing it(within last month or so). Haven't got to checking the timing yet. Thanks
Old Mar 6, 2005 | 02:53 PM
Lmgrcivic's Avatar
check your injectors and your fuel pump and your throttle cable when you let off the gas it might close to much I had this problem before the nuts on the adjuster started to come loose and move.
Old Mar 6, 2005 | 03:48 PM
97dxnut's Avatar
Default Re: Engine Stalls (Lmgrcivic)
any other symptoms? sluggish throttle response? when was the last time you did a tune up?
Old Mar 6, 2005 | 04:32 PM
b18civic1993's Avatar
i would do a tune up. like plug's wires the works being as u just swaped it recently. who knows when the last time anything was changed. sometimes stupid stuff causes little problems. check the pcv valve to. my buddies car did the same thing and after every time we started it and tested it and after fuel filter, PCV valve, and fuel filter it worked fine.
MI4$DC5
79
Apr 13, 2010 11:13 AM
jdm mini me
11
Mar 28, 2010 05:22 PM
capm.stabahoe
Dec 27, 2008 06:17 PM
mtownsi
Jun 3, 2006 07:14 PM
dobbs1027
Dec 28, 2004 03:17 PM
