Will my B16A2 water pump work on my LS B18A
Old Mar 5, 2005 | 05:28 PM
1SlowSi's Avatar
Default Will my B16A2 water pump work on my LS B18A
Just a question because i just bought an LS block and just bought a new water pump for the B16.
Old Mar 6, 2005 | 04:22 AM
D-tuned's Avatar
Default Re: Will my B16A2 water pump work on my LS B18A (1SlowSi)
yes it will work but your going to have to buy a B16 timing belt. the LS water pump has 19 teeth and the vtec water pumps(b18c,b16) has 22 teeth. so if you use a vtec water pump you have to use a vtec timing belt.
Old Mar 6, 2005 | 06:55 AM
egsleepercivic's Avatar
actually I think you will need a Gsr timing belt, not sure though
Old Mar 6, 2005 | 07:12 AM
1SlowSi's Avatar
Default Re: (egsleepercivic)
yeah i just put on a brand new timing belt and waterpump on the b16 and i dont wanna waste it. So if i can use b16 waterpump/belt on the ls block/gsr head im good.
B18A block and GSR head.
Old Mar 6, 2005 | 07:23 AM
1SlowSi's Avatar
Default Re: (1SlowSi)
so basically if you use a vtec water pump, you can use any vtec belt.
Old Mar 7, 2005 | 05:08 AM
1SlowSi's Avatar
verify this please
Old Mar 7, 2005 | 06:13 AM
mmuller's Avatar
Mad Scientist
no not any vtec t-belt. any vtec timing belt but the one from a b16/b17 since its shorter.
b18c/b18c5 will work
Old Mar 7, 2005 | 06:35 AM
1SlowSi's Avatar
Default Re: (mmuller)
Damn. I have a freakin brand new B16 waterpump and belt. And i cant freakin use it. Well i can use the pump, but I have to use a GSR belt? If the blocks are the same size, but the head is only slightly taller, why wouldnt the belt work? It would take away a LITTLE deflection on the belt.
Old Mar 7, 2005 | 07:07 AM
mmuller's Avatar
Mad Scientist
b16 and b18 blocks are not the same size
Old Mar 7, 2005 | 09:09 AM
1SlowSi's Avatar
whoops. my bad. i was always told that the blocks were and that the heads were different.
Okay, so.... with my b16 waterpump on the LS block i have to use a GSR timing belt?. Ive heard a couple diff. answers thats why i ask again. lol.
Old Mar 7, 2005 | 10:27 AM
EG6 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">no not any vtec t-belt. any vtec timing belt but the one from a b16/b17 since its shorter.
b18c/b18c5 will work</TD></TR></TABLE>
Theres your answer
Old Mar 7, 2005 | 10:40 AM
1SlowSi's Avatar
Default Re: (EG6 SiR)
good to go. Thats a waste of ****** $55. think someone will buy it from me?? lol $20 shipped
Old Mar 21, 2005 | 02:29 PM
1SlowSi's Avatar
how many teeth are on a b16 pump. And to confirm all these posts cause im about to freakin put all this together... on my B18A block, i can use my b16 water pump, and run a GSR timing belt being im using a GSR head?? i want to be 100% sure cause ive read a bunch of different answers.
Old Mar 21, 2005 | 05:59 PM
NJIN BUILDR's Avatar
Vtec pumps have 22 teeth,non have 19.Lsvtec with ls pump uses ls belt,with vtec pump it uses gsr belt.
Glenn
crx-si
Apr 29, 2008 06:22 AM
B6tizzleHatch
14
Aug 14, 2006 08:49 PM
mycrx7
14
Jun 14, 2005 02:14 AM
hatchii
Jun 9, 2003 10:19 PM
avividmemory
Jan 9, 2003 03:03 PM
