throwing code 4 on h22a vtec turbo
Old Mar 5, 2005 | 05:18 PM
PreludeSiTdriver's Avatar
Default throwing code 4 on h22a vtec turbo
I was doing a compression test and after I put my wires back on turned the car on, it gave me the code. I cant seem to figure out where the crank pos censor is on the prelude. I also switched the dizzy also did a continuity test and resistence test as well and everything worked fine upto the wires that go into the ecu. I have a p28 running hondata. Could my ecu be gone or do I nee to reset my chip/program?
Old Mar 5, 2005 | 10:45 PM
PrettyLude's Avatar
what year is the lude?
Old Mar 6, 2005 | 07:32 AM
Default Re: (PrettyLude)
its a 94 fully built motor h22a obd1. i swapped ecu with my friend and it worked fine no codes or anything.
Old Mar 6, 2005 | 04:39 PM
PrettyLude's Avatar
possibly a bad chip?
Old Mar 7, 2005 | 02:56 PM
tried a skunk2 chip still had the code
Old Mar 7, 2005 | 03:31 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (PreludeSiTdriver)
Have you tried clearing the ECU codes? Does it come back?
Sns8504
Oct 22, 2017 05:56 PM
logicdc
Engine Management and Tuning
Nov 18, 2008 01:22 PM
logicdc
Nov 18, 2008 11:37 AM
