Mike K, I have a couple questions about the 30K mile check-up
Old Jan 21, 2002 | 07:28 PM
CW-ITR-329's Avatar
Default Mike K, I have a couple questions about the 30K mile check-up
What exactly does Acura do when this is done? Also, Can I do it myself? And.. Do you have a package you sell? I am at 33K, should I get my valves adjusted. Thanks, Ryan
Old Jan 21, 2002 | 07:56 PM
Mike K's Avatar
Default Re: Mike K, I have a couple questions about the 30K mile check-up (CW-ITR-329)
30k consists of air filter, valve adjust, brake fluid flush, oil change, and rotate/balance.
You could do the valve adjustment yourself.
Are you the guy who works at Devoe Cadillac?
Reason I ask is, there's not many white ITR's around here.
Old Jan 22, 2002 | 02:34 AM
CW-ITR-329's Avatar
Default Re: Mike K, I have a couple questions about the 30K mile check-up (Mike K)
No, I work at The sports authority. Just got the car a month ago. Yours is the one with the CF hood, right? NICE! Arent you supposed to do cap and rotor and spark plugs? How hard is it to do your own valve adjustment? Thanks, Ryan
Old Jan 22, 2002 | 05:26 AM
Its_real&its_spectacular's Avatar
New User
Rotor is not a bad idea (Use a genuine one.) Adjusting your valves isn't very hard at all if you spring for the tool. (either Snap-on or the Honda one.) You only replace distributor caps on these cars if something is specifically wrong with the old one. Just clean the little deposits off the 4 terminals and re-use the current one...
Old Jan 22, 2002 | 06:44 AM
IntegraT's Avatar
Default Re: Mike K, I have a couple questions about the 30K mile check-up (Its_real&its_spectacular)
I've never heard this before, why is that?
Old Jan 22, 2002 | 08:57 AM
Mike K's Avatar
Default Re: Mike K, I have a couple questions about the 30K mile check-up (IntegraT)
On a factory ignition system, distributor caps RARELY take a .
MSD seems to put more wear on the cap and rotor.. but on a stock motor, only the rotor needs replacement more frequently.
EteBoy
Honda Civic (2001 - 2005)
Nov 14, 2009 10:24 AM
samsteinf22a
Jun 24, 2004 10:08 AM
daewonder.
Feb 16, 2003 01:33 PM
homegrown96734
Jul 15, 2002 08:33 AM
FifthGearOnline
Feb 27, 2002 08:11 PM
