Honda N1 CTR Pulley Belt Size for B18C
Old Mar 5, 2005 | 05:30 AM
AlxSiR7's Avatar
Default Honda N1 CTR Pulley Belt Size for B18C
i want to install this honda n1 crank pulley on my jdm b18c, but i need to know the correct belt size. i've searched and these are all the different answeres i've found:
CTR N1 Crank Pulley Belt Part Number:
Autozone belt number: 290K4 (extended p/n is 4PK735)
4PK 755
4PK stands for 4 ribbed
755 is 755mm
The part # is 56992-P1R-004 Acura 2.5TL power steering belt
acura TL alternator belt also works
goodyear belt size number 4pk735
it's the same part number as the alternator belt for a 94 acura vigor
the belt you need is a 655mm belt with 4 grooves
it's close to 25 3/4"
...::sigh::.. so if anyone has put this pulley on their b18c & is 120% positive of a certain belt size please respond. i don't need anymore "pretty sure" answers.
Old Mar 5, 2005 | 06:00 AM
SLIPSTICK TIPPIN's Avatar
Default Re: Honda N1 CTR Pulley Belt Size for B18C (AlxSiR7)
yup bump dizzle
Old Mar 5, 2005 | 06:19 AM
Racermech's Avatar
Default Re: Honda N1 CTR Pulley Belt Size for B18C (importelegente)
I did not realize the the NI was also under driven.
So same question for me, for it would be on a 18B. Maybe the same size as the 18C??
thanks
Old Mar 5, 2005 | 08:50 AM
jDMJeRk's Avatar
couldnt you use the b16 belt? I dont get it, its what I have, I could get the number for you... Sounds like youve boughtin a lot of belts!
Old Mar 5, 2005 | 05:17 PM
AlxSiR7's Avatar
..bump
Old Mar 5, 2005 | 06:32 PM
Jwbetley's Avatar
isnt the N1 alternator only?
i guess im mixed up
Old Mar 5, 2005 | 06:39 PM
AlxSiR7's Avatar
Default Re: Honda N1 CTR Pulley Belt Size for B18C (Jwbetley)
yea.. no a/c or p/s.. just crank to alternator, but it's underdriven slightly
Old Mar 5, 2005 | 07:05 PM
Jwbetley's Avatar
I have an N1 pulley as well. What do you mean "slightly underdriven?"
Now, i put mine on, and the tdc is not really lined up as well as i wish it would be. It is like, 3 mm off,not enough that it can be corrected by skipping a tooth. is this normal or did i mess something up. Is it pulley a little off? also, just a simple question... I put my timing belt on today.. how tight should i tention it?
Old Mar 5, 2005 | 07:11 PM
AlxSiR7's Avatar
dude.. what a thread jacking
Old Mar 5, 2005 | 07:35 PM
Jwbetley's Avatar
sorry... no jacking intended
Old Mar 6, 2005 | 05:51 PM
AlxSiR7's Avatar
guess no one knows for sure
Old Mar 7, 2005 | 07:46 AM
Racermech's Avatar
Damn, no real answer.
Have you tried either the PS or AC belt??
I think mine will go on next weekend if the weather stays nice.
Maybe just go to pepboys or sometihng and see if anone will look for a belt the is about 655mm and just use the tensioner to pull it tight. Thst is if it is within a couple of MM
Old Mar 7, 2005 | 07:56 AM
AlxSiR7's Avatar
Default Re: Honda N1 CTR Pulley Belt Size for B18C (Racermech)
well i'm putting mine on tonight & i just went to autozone and bought a 735mm belt. looks good by just eyeing it, but i'll let you know how it fits when i get home from work.
Old Mar 7, 2005 | 09:38 AM
teknoracing's Avatar
Bump for an answer, i sell these on ebay and it would help if i knew what belts people should buy and maybe include them in the auction as well
Old Mar 7, 2005 | 11:01 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Why would you need a non-OEM size belt? Wouldn't it be the same belt as OEM???
You can adjust the tension on the alternator to accomadate a dif size belt. Are the serpentine grooves dif on the N1? I would think they would have to be same as stock or else you'd need a different alternator.
I have an ATI Damper on mine and it uses all the stock belts and is lighter then the OEM Damper too.
Old Mar 8, 2005 | 07:04 AM
AlxSiR7's Avatar
found the correct belt.. made a new thread here: https://honda-tech.com/zerothread?id=1171612
Blk00EJ8
Apr 12, 2008 05:44 PM
crxb20ed
Jan 9, 2005 01:16 PM
Unjockable
Nov 25, 2003 07:02 PM
01-0338R
Sep 26, 2003 08:06 PM
MattD@Stoptech
Jul 30, 2003 09:36 AM
