help a fellow hf owners
I need help with my planned swap i would like to drop a d16a6 motor in to my 91 crx hf. can some one help me with a guide on doing this? this will be my first swap upgrading slowly but surely.
honestly man... its real late and I don't feel like looking for a guide myself. So here is a free bump and a lil advice. I know there are countless thread on engine swapping. This swap ought to be VERY straight forward and good for a beginner.
Make sure to get the A6 tranny too.
The D16a6 will bolt right in. Take the HF motor out and put the Si motor in. You will have one plug on the back of the engine harness that wont plug into anything(small 2 wire plug) just leave it.
If you are swapping the Si tranny too then you will need the Si or DX axles and ftont hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic »</TD></TR><TR><TD CLASS="quote">The D16a6 will bolt right in. Take the HF motor out and put the Si motor in. You will have one plug on the back of the engine harness that wont plug into anything(small 2 wire plug) just leave it.
If you are swapping the Si tranny too then you will need the Si or DX axles and ftont hubs.</TD></TR></TABLE>
Everything was right except for the last part, as long as you retain your stock axles you do not need to swap hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
Everything was right except for the last part, as long as you retain your stock axles you do not need to swap hubs.</TD></TR></TABLE>
HF axles will not fit in the Si tranny. Thats why you need to swap the hubs and use the Si axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic »</TD></TR><TR><TD CLASS="quote">HF axles will not fit in the Si tranny. Thats why you need to swap the hubs and use the Si axles.</TD></TR></TABLE> HF axles will fit in the si tranny .................... I DID IT , apperently you dont have a hf , so dont post if you dont know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote"> HF axles will fit in the si tranny .................... I DID IT , apperently you dont have a hf , so dont post if you dont know.</TD></TR></TABLE>
so did i.....
so did i.....
To go further into detail. HF axles fit into SI tranny, and SI axles fit into HF tranny. However, the hubs are what are different. HF axles will not fit into SI hubs and SI axles will not fit into HF hubs.
Interesting eh?
Gay I think!
Interesting eh?
Gay I think!
Yeah....The axels controversey is a problem. These guys are right dude, get the a6 tranny, and get the SI Front end. The whoel Springs/struts, brakes, arms...all that good stuff. Trust me teh Hf axles are toothpicks....you don't want that SI tranny/motor running on those. You won't snap them but it is nice to have better axels witha better motor. And from a fellow Hf owner to another....good luck dude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic »</TD></TR><TR><TD CLASS="quote">If you are swapping the Si tranny too then you will need the Si or DX axles and ftont hubs.</TD></TR></TABLE>
WRONG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h »</TD></TR><TR><TD CLASS="quote">HF axles fit into SI tranny, and SI axles fit into HF tranny. However, the hubs are what are different. HF axles will not fit into SI hubs and SI axles will not fit into HF hubs.
RIGHT!
****** RIGHT!
to H-T members who spread bad info.
I used 5 speed axles out of a 4 door EF in my HF trans with non HF knuckles.
4 speed EF axles are exactly like HF axles.
Autos? I don't know. Call AutoZone and see if they're the same pt # as an Si.
I wouldn't worry about breaking them unless you're running slicks or you're some kind of bun out king. HF are light hollow tube axles. I felt bad pulling them off of my HF to replace them with heavy solid axles.
WRONG
RIGHT!
****** RIGHT!
to H-T members who spread bad info.I used 5 speed axles out of a 4 door EF in my HF trans with non HF knuckles.
thanks for helping ok let me get this straight when i swap out the hf motor and put the Si motor in there gonna be a single two wire plug that is gonna be not used (what is this plug for??)...... and i can use my stock HF axles and hubs with the Si tranny ??
thanks for the quick replies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Serdar »</TD></TR><TR><TD CLASS="quote">...... and i can use my stock HF axles and hubs with the Si tranny ??</TD></TR></TABLE>
Have you read any of the help we've given you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">as long as you retain your stock axles you do not need to swap hubs.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote"> HF axles will fit in the si tranny .................... I DID IT </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirq2u »</TD></TR><TR><TD CLASS="quote">so did i.....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h »</TD></TR><TR><TD CLASS="quote">To go further into detail. HF axles fit into SI tranny, and SI axles fit into HF tranny. However, the hubs are what are different. HF axles will not fit into SI hubs and SI axles will not fit into HF hubs.
I have a question about the hf tranny linkage? I am puting a dx motor with an si tranny and I can't get the linkage off of the hf tranny, it is not like the linkage on my dx. Do I need dx or si linkage to make this work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adeline »</TD></TR><TR><TD CLASS="quote">I have a question about the hf tranny linkage? I am puting a dx motor with an si tranny and I can't get the linkage off of the hf tranny, it is not like the linkage on my dx. Do I need dx or si linkage to make this work?</TD></TR></TABLE>
there the same....
there the same....
<FONT SIZE="2">Search -=></FONT> Bitch Pin
