Going JRSC, What are must-have's?
Old Mar 4, 2005 | 08:03 PM
Boarderx192's Avatar
Default Going JRSC, What are must-have's?
So Im going with the JRSC. I need to know what are must haves with this setup. If you were going with the JRSC, what do I need to buy/get/do, to Make this my DD? This also needs to pass NY inspection so it cant throw codes. I know tunning is Extremely important and Im not going to skimp out on that. I am having my local shop install it so I dont need to worry about that, But I dont know what kind of fuel management (uberdata/ hondata, NO EMS) I should get, injectors 400cc/450cc, ect. If you were on a limited budget, What would you get?
Old Mar 4, 2005 | 09:36 PM
01 LudeDude's Avatar
Default Re: Going JRSC, What are must-have's? (Boarderx192)
Hondata S200
450cc Injectors
Have you already done I/H/E ?
Old Mar 4, 2005 | 11:30 PM
Default Re: Going JRSC, What are must-have's? (01 LudeDude)
Yes I already have I/H/E. What kind of 450cc injectors should I get?
Old Mar 5, 2005 | 03:47 AM
Sticky Tires's Avatar
* B A N N E D *
PM Sharkcohen on this board. He's the JRSC guru. If not, he'll find this thread, he can sense it!
Old Mar 5, 2005 | 10:05 AM
Default Re: Going JRSC, What are must-have's? (Sticky Tires)
Already have. Havent heard back from him
Old Mar 5, 2005 | 10:18 AM
2kflamedlude's Avatar
Good luck.. I would go with a turbo kit..
Old Mar 5, 2005 | 10:22 AM
esca's Avatar
Default Re: Going JRSC, What are must-have's? (2kflamedlude)
hes also on preludeonline.com very often
whoring the OT forums =p
Old Mar 5, 2005 | 10:40 AM
chihuahuamanx's Avatar
Default Re: Going JRSC, What are must-have's? (esca)
on the base boost level some 450's are going to be overkill, and since this is your DD id go with something smaller to make the tuning (as far as mpg) a little easier. Id also get a new fuel pump. theyre pretty cheap, and just good insurance. Most shops around here wont touch anything with any FI without a new pump. Our pumps are supposed to be able to handle 300hp, but hell its not even $100.
You really should also look into a new clutch. Its often overlooked until a month later when your slipping like a penguin on cat ****.
Old Mar 5, 2005 | 10:55 AM
Default Re: Going JRSC, What are must-have's? (chihuahuamanx)
I have a centerforce dual friction clutch, fidanza flywheel, Intake, Headers, Exhaust. Wher should I get the injectors from? Also, If I go with Hondata, i will need to go from OBD 2 to OBD 1 thus not being able to pass inspection. what are other options? I was lookin at getting an AEM FPR Fuel Rail and a Walbro(sp?) fuel pump.
Old Mar 5, 2005 | 11:05 AM
man, making real power and staying smog legal is really tough. I would get it smogged now, and pass ref, then be ready to swap some stuff in a coupld years.
i dunno about the aem, but the walbro is absolutely awesome. A bit on the loud side, but i dont have my seats in, and they would definetly quiet it down. The walbro is soo easy to install i crapped my pants.
Old Mar 5, 2005 | 11:25 AM
98vtec's Avatar
moderator emeritus
if your on a limited budget then i wouldnt even talk about a jrsc
you gotta pay to play
Old Mar 5, 2005 | 11:47 AM
4bidden's Avatar
Default Re: Going JRSC, What are must-have's? (98vtec)
A spare engine.
Old Mar 5, 2005 | 12:26 PM
* B A N N E D *
Default Re: Going JRSC, What are must-have's? (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">A spare engine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">if your on a limited budget then i wouldnt even talk about a jrsc
you gotta pay to play</TD></TR></TABLE>
The big boys come out and speak nothing but truth.
Old Mar 5, 2005 | 06:47 PM
Nick M's Avatar
A JRSC on a limited budget?
Yikes.
What kind of header do you have? I wouldnt even bother with a JRSC unless I had a really nice piece with atleast a 2.5" collector.
uncledan
Aug 18, 2008 09:39 AM
gosu08
Jan 10, 2007 05:07 PM
Boarderx192
Mar 5, 2005 07:21 PM
ModAddict
Dec 13, 2002 08:13 PM
