i need imediate help
Old Mar 4, 2005 | 04:33 PM
GSRerrr's Avatar
Default i need imediate help
all i have are socket tools i was wondering if i that will suffice? im having a hard time any tips?? plus bolts holding b-pipe to header are almost impossible to to reach with socket wrench. i have a 00 GSR please help anyone
thanks in advance
Old Mar 4, 2005 | 04:48 PM
GSRerrr's Avatar
Default Re: i need imediate help (GSRerrr)
anyone??? up
Old Mar 4, 2005 | 04:50 PM
jasonw's Avatar
You didn't really explain what you need help doing...
Do you have a socket extension?
Old Mar 4, 2005 | 04:57 PM
SonicBlueTeg's Avatar
are you having problems breaking the bolts loose under the car on the piping?
if you have a floor jack handle or longer metal pipe you can slip it over the socket to make the handle longer to get more leverage..
Old Mar 4, 2005 | 05:00 PM
GSRerrr's Avatar
Default Re: i need imediate help (SonicBlueTeg)
im havin trouble loosing the 12mm header bolts, like straight from exhaust, and bolts from B-pipe. all i have is socket wrench, i was wondering if u had any tips on how to loosen it juss by workin with simple tools. is impact gun like a guaranteed needed thing?
Old Mar 4, 2005 | 05:04 PM
GSRerrr's Avatar
ok i take back the part about exhaust nuts i got those out, now its just the b-pipe bolts under the A-pipe i think thats wat its called, sorry im a bad explainer, but if any understands feel free to help.
thanks in adavance up
Old Mar 4, 2005 | 05:14 PM
C4wrx's Avatar
spray the nuts with liquid wrench or wd40 and them sit for a little bit.
Old Mar 4, 2005 | 05:19 PM
GSRerrr's Avatar
Default Re: i need imediate help (C4wrx)
thanks dawg
Old Mar 4, 2005 | 05:55 PM
PLAGUED_DB7's Avatar
they are fucken hard to get off...I went to the muffler shop and had them do it, as well as put new hardware with a good coat of anti seize (in case of future mods)
Old Mar 4, 2005 | 06:02 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRerrr &raquo;</TD></TR><TR><TD CLASS="quote">thanks dawg</TD></TR></TABLE>
W0rd ta y00 MaMm@!!
You could always 'immediately' run down to the local tool store and 'immediately' buy a 12mm open end wrench then 'immediately' get your *** home and 'immediately' pull the header off with that.
Just like the other guy sade 'immediately' above me, you can use a pipe and slip it over the wrench and get 'immediate' results which would equate to 'immediate' satisfaction.
Old Mar 4, 2005 | 06:08 PM
GSRerrr's Avatar
Default Re: i need imediate help (Haleiwa-Brando)
dude this is rly sad.. i mean i got everything off but the b-pipe bolts, i have a wrench but eat time i turn it looks like its giving way, but instead im strippin the bolt, any ideas??? im totaly bummed out
thanks
Old Mar 4, 2005 | 08:50 PM
a1320addict's Avatar
spary em down with lubricant and get a small size torque wrench..presto
blackccoupe
Sep 23, 2010 08:13 PM
Tensa_Zangetsu
Dec 20, 2007 07:29 PM
jweezy225
Jun 19, 2004 06:33 AM
ophdehEEzY
Mar 5, 2003 09:02 AM
SamC
Feb 28, 2002 07:37 AM
