Load poping noise when I turn or brake(not cv joint)
Old Mar 4, 2005 | 10:32 AM
scoobyghost's Avatar
Default Load poping noise when I turn or brake(not cv joint)
I have a poping sound when ever i turn or when i apply the brakes to stop.Its not the cv joint what else can it be. 93 civic lx. Thanks
Old Mar 4, 2005 | 10:40 AM
Ricey McRicerton's Avatar
Default Re: Load poping noise when I turn or brake(not cv joint) (scoobyghost)
I've had the same problem on and off with mine. I've yet to figure it out.
Old Mar 4, 2005 | 10:55 AM
ScoobCivic's Avatar
does it happen when you throttle too fast from a take off or when you launch? and if so, does it happen in reverse also?
Old Mar 4, 2005 | 12:14 PM
ssbpturbohatch's Avatar
i've heard noise like you describe on some girls prelude(99) when i worked at a honda dealership and it turned out to be the rack and pinion. may be same thing on yours.
Old Mar 4, 2005 | 01:04 PM
95cxhatch's Avatar
Default Re: Load poping noise when I turn or brake(not cv joint) (ssbpturbohatch)
have you checked ALL your front end bushings??...wheel bearings??...inner and outter tie rod ends??
one of my friends cars was doing something like this and he said turned out to be a loose brake pad due to a sized piston and was flopping and slapping when you hit the brakes hard made a clunk, weird tho .
Old Mar 4, 2005 | 01:08 PM
pdiggitydogg's Avatar
I had something similar, that turned out to be upper ball joints (A-arm).
Old Mar 4, 2005 | 01:16 PM
95cxhatch's Avatar
Default Re: (pdiggitydogg)
my car did it with bad upper ball joints too, so i took my buddies A-arms form his teg and i swapped out my wornout top bushings and replaced it with his dropzone camber kit he gave me now my car creeks and clunks now too but that is because of the F**KIN horrible dropzone camber kit
adjustable skunk2 A-arms on the way
Old Mar 4, 2005 | 01:19 PM
yeah......I had junk2 arms. They died in about a year.
I replaced with SPC arms, which have joints that are MUCH easier to replace. I am much, much, much happier
Old Mar 4, 2005 | 02:14 PM
Turbo E's Avatar
front LCA bushings for me. hit the gas...*CLUNK* hit the brakes...*Clunk*
Old Mar 4, 2005 | 04:00 PM
95cxhatch's Avatar
Default Re: (Turbo E)
thats exactly what happens with my dropzone camber kit, GRRRRRRR
quiet4no1
Jan 3, 2014 03:03 PM
picthis1
Feb 1, 2012 08:32 PM
chrisw
Mar 26, 2004 08:07 AM
Matgallis
Feb 20, 2004 07:21 AM
tyflip2
12
Nov 22, 2003 07:42 AM
