bottom end bulid
Old Mar 4, 2005 | 08:06 AM
b16a27's Avatar
Default bottom end bulid
if i get my bottom end completely done in my b16a 12:1 compression rods crank all that **** new Bering's oil pump water pump do u think ill be able to feel the difference big time or a little bit like how much more power will it give me all i have done now is i/e/h lighter flywheel any opinions.
Old Mar 4, 2005 | 08:12 AM
wilsel's Avatar
Default Re: bottom end bulid (b16a27)
I don't think you'll feel that much 10HP tops I'm betting
Old Mar 4, 2005 | 09:23 AM
00Red_SiR's Avatar
All Motor Mentor
Unless you change your cams or do some headwork, that bump in compression will only yeild about an 8% gain in power (4% for every 1 full point gain in comp) or 10-12 hp. Unless you're doing a stroker kit I see no reason for changing the crank or rods. Simply using CTR pistons and a thin headgasket could get you to that 12:1 comp ratio in a B16a.
513honda
Dec 26, 2013 06:40 AM
EG Coupe Frank
Jan 4, 2009 12:06 PM
GreddySi99
Sep 27, 2003 06:44 AM
-KangaRod-
Aug 26, 2003 09:28 AM
B19CivicHB
Mar 7, 2002 07:54 PM
