How change automatic transmission to manual?
Old Mar 4, 2005 | 02:16 AM
MAD-racer's Avatar
Default How change automatic transmission to manual?
Hello! I'm from Russia and i'm sorry for my bad english . But i need help experts . I have honda civic ef 89 d15b with the automatic transmission. I want toreplace it to mechanical. Where it is possible to find manual on this work? Or may be someone tell me about this? Thanks!
Old Mar 4, 2005 | 06:14 AM
Magick211's Avatar
Default Re: How change automatic transmission to manual? (MAD-racer)
Lets see. you will need the follwing
manual pedal assembaly.
shift linkage
tranny
clutch cable
also a few more things that im sure i left out
Old Mar 4, 2005 | 07:52 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Welcome to Honda-Tech..
Check these links:
http://www.trinituner.com/shop/manual.asp
http://hometown.aol.com/jrmupzaii/auto2man.html
Old Mar 4, 2005 | 01:53 PM
MAD-racer's Avatar
Default Re: How change automatic transmission to manual? (88DXCRX)
Thanks
But i have one more problem. I can't find in my city manual pedal assembaly, shift linkage, tranny, clutch cable. Whether these devices can approach from Integra, Prelude, Civic 92+ or civic 84-88?
Old Mar 4, 2005 | 03:24 PM
vegaskurt's Avatar
I'm in the middle of doing this swap. Pedals from the 88 through 91 will fit. They are a pain to remove and put back in. Shift linkage for the same years and a tranny will work fine.
You will also need a new starter, flywheel, clutch, clutch cable and possibly flywheel cover (trying to figure that one out now)
Oh, you can keep your stock ECU, but I believe the check engine light will stay on once the Auto tranny is gone.
Old Mar 4, 2005 | 03:59 PM
4drEF's Avatar
Keyboard Humorist
Default Re: How change automatic transmission to manual? (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the middle of doing this swap. Pedals from the 88 through 91 will fit. They are a pain to remove and put back in. Shift linkage for the same years and a tranny will work fine.
Oh, you can keep your stock ECU, but I believe the check engine light will stay on once the Auto tranny is gone.</TD></TR></TABLE>
Starters are different?
When I did mine I put a starter on... but it was either from a 92~95 or it was from my automatic. Both bolted up to the manual tranny no problem.
The black access plate is DEFINITELY different.
Old Mar 4, 2005 | 04:25 PM
vegaskurt's Avatar
Default Re: How change automatic transmission to manual? (4drEF)
The auto and manual starters for the 88-91 have different part numbers. I assume because the auto doesnt have a flywheel.
So the flywheel/tourqe converter covers are not the same.... Back to the junk yard for me
Old Apr 27, 2005 | 02:35 PM
MAD-racer's Avatar
Hi! I have replaced a automatic transmission to manual, and together with the engine. The engine and a manual transmission have been taken with civic EG-4. Therefrom and all devices. On all this at me month has left.
black0hatch
Jan 29, 2010 04:59 AM
JDM Aholic
Jan 13, 2006 04:15 PM
bman511
Jul 1, 2005 07:04 PM
BigPlansNoMoney
Dec 29, 2004 12:53 PM
damitzrichard
Nov 26, 2001 01:50 AM
