wiring for evap purge control solenoid
does anyone know where the 2-wire from the evap purge vavle goes to? does it go directly to the ecu? if so, which pins do i hook them up to?
ok i did some more searching around and i found im suppose to wire it up to pin A20. am i right? however i thought there were 2 wires? not just 1?
also is it suppose to throw a CEL if its not hooked up?
cuz mine isnt hooked up and its throwing no CEL at all.
im also using a 94gsr ecu for my 96 b18c swap if that helps.
i think im using the jdm harness that came with the motor so im pretty sure there is no 2-wire for the evap purge vavle? am i correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg_baLLa »</TD></TR><TR><TD CLASS="quote">ok i did some more searching around and i found im suppose to wire it up to pin A20. am i right? however i thought there were 2 wires? not just 1?</TD></TR></TABLE>You're right about pin A-20. The other wire is power from the main relay. The ECU closes the ground side of the circuit when it wants to energize the relay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg_baLLa »</TD></TR><TR><TD CLASS="quote">also is it suppose to throw a CEL if its not hooked up?
cuz mine isnt hooked up and its throwing no CEL at all.</TD></TR></TABLE>I always thought it would throw a CEL, but I just looked in my '95 list & there isn't any code for EVAP. So maybe you're right??
yeah tahts why i will never use obd2 ecu. i do not have the time nor the money to get all that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">I always thought it would throw a CEL, but I just looked in my '95 list & there isn't any code for EVAP. So maybe you're right??
isn't it code 91? Evaporative Emission Control System insufficient purge flow.
or is that a code for obd2 ecu's?
