ukdm speedo in my 88 swap?????????????
Old Mar 3, 2005 | 07:24 PM
88cerx's Avatar
Default ukdm speedo in my 88 swap?????????????
i bought a ukdm speedo and it goes to 150 will the speed read correctly or will i have to replace a part-in the trans
Old Mar 4, 2005 | 08:35 AM
88cerx's Avatar
Default Re: ukdm speedo in my 88 swap????????????? (88cerx)
Old Mar 4, 2005 | 08:37 AM
EP3_05's Avatar
As long as the ukdm cluster uses the mechanical vss then it will just be plug and play as long as the cluster is an 88 or 89 cluster. If it is an electrical vss cluster you will need an electronic vss assembly.
Old Mar 4, 2005 | 12:01 PM
88cerx's Avatar
Default Re: ukdm speedo in my 88 swap????????????? (91civic)
ok so i swaped it in the wiring was different but got it to work the speedo works mint but on the ukdm harness there is a green/white and white/green not used evrey wire was color cooridinated accept those 2 on the cluster and also on the car there was a red wire that was not connected any info on those 3 wires would be great
Old Mar 4, 2005 | 12:23 PM
88cerx's Avatar
i herd the white/green might be the low feul indicator but thats it
Old Mar 4, 2005 | 03:29 PM
88cerx's Avatar
bump
Old Mar 5, 2005 | 05:31 PM
88cerx's Avatar
still need to know
Old Mar 6, 2005 | 12:13 PM
1gEF-8's Avatar
what year speedo
Old Mar 6, 2005 | 12:18 PM
88cerx's Avatar
Default Re: ukdm speedo in my 88 swap????????????? (1gEF-8)
88-89
Old Apr 6, 2005 | 12:33 PM
Loaded Butane's Avatar
Did you have to rewire anything to get the tach to work?
edit - nevermind i see some rewiring is in order. Just repin some wires to match colors. No big deal
Modified by Loaded Butane at 8:36 PM 4/6/2005
Jumpa-Digital
Honda Civic (2001 - 2005)
Feb 19, 2018 04:11 AM
B16Civic93
Feb 21, 2012 02:15 AM
french_yogi
Apr 18, 2011 06:24 PM
ef-b16sedan
Jul 7, 2006 01:21 PM
