Oil found in all 4 spark plug holes?
Hi guys, I was changing out my spark plug wires today and when i popped the first one off I found the hole filled in oil. Then i went to see if all the other holes was the same and all 4 of the spark plug holes are filled with oil? what could cause this to happen?
Thanks in advance,
Saki
added a pic for more replies...
Modified by Saki at 8:57 PM 3/4/2005
Thanks in advance,
Saki
Here's my writeup on how to replace the valve cover gasket and spark plug seals:
http://www.dmcknight.net/crxho....html
Ok I replaced all four of those O-Rings... and oil is still getting in the spark plug hole. I check the valve gasket and it perfectly fine. I had a question. I have a B16A1 engine, but my valve cover is from a B16A2 engine. Would that cause the oil to get into the spark plug holes?
-Saki
-Saki
make sure you silicone those badboys up.... If doing that doesn't work, then its the actual valvecover...this was the case on my integra. it was seeping through the "metal rings".... well, where the top of the spark plug wire plugs into the hole, and actually slightly inside. i siliconed the top of that area.
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
VTEC_Du_Ma_Mai
Sep 5, 2008 01:41 PM
mailforjon
Aug 5, 2002 04:34 PM
