b16 radiator fan problems......need HELP!
Old Mar 3, 2005 | 12:40 PM
tokes's Avatar
Default b16 radiator fan problems......need HELP!
i recently installed a new T-stat on my B16 and now the fan wont turn on. i changed the radiator and flushed the system but i fan still doesnt turn on even after 20mins of idleing. i also bought a new fanswitch thinking that would solve my problem but im still getting the same results. do you guys think i need a new waterpump?
thanks in advance guys!
Old Mar 3, 2005 | 12:43 PM
eK9aT10pSi's Avatar
Default Re: b16 radiator fan problems......need HELP! (tokes)
after you filled the system up, did you let the car idle up with the cap off getting rid of the air ...
Old Mar 3, 2005 | 12:52 PM
dantastic's Avatar
is it really cold where you live? i know my car can be idling more than 10 min and my fan doesn't turn on b/c my car still isn't warm enough
Old Mar 3, 2005 | 01:47 PM
tokes's Avatar
Default Re: (dantastic)
yup i let it warm up without the cap on..
and its not cold where i live.
Old Mar 3, 2005 | 04:33 PM
eK9aT10pSi's Avatar
Default Re: (tokes)
while you have the cap off and motor running, do you have the heat all the way up at full blow ?
Old Mar 4, 2005 | 08:16 AM
dubzxallxstar's Avatar
which fan switch did u change the one on the block next to the front radiator hose.... or the cooling fan relay switch thats inside the fuse box next to the battery...hope this help...
jmg5e
Jul 22, 2015 02:34 PM
chrisalvar
Jan 29, 2012 05:15 PM
InterludeTypeR
Jun 20, 2009 08:13 PM
Nino_eg6
Jan 28, 2009 02:28 PM
DC5RK20A
Jun 16, 2004 06:16 PM
