overheating issue
Old Mar 3, 2005 | 11:11 AM
decible01's Avatar
Default overheating issue
Ok so the other day my car overheats, no hot air from heater, bottom radiator hose cool, top hot and hard. Thermostat right? Well I changed it with a failsafe one that locks open if it goes bad. Put it in started car, topped everything off. was still blowing cool for a few. turned it off, let it cool, topped it off again. next day I was driving around all day with heat at normal temp. Then all of a sudden the temp goes way up, not to the red but pretty damn high(fan is on). Heat is still working so I know its not the Tstat. after a few it drops to normal. runs normal for a few then jumps back up till I got home. what could be wrong? please help me out.....
now today its overheating still, hoses are hard, and I get no heat. Well I had heat for a few minutes then nothing.
Old Mar 3, 2005 | 02:25 PM
NJIN BUILDR's Avatar
Default Re: overheating issue (decible01)
Might still be air in the cooling system,but sounds more like head gasket.Most repair shops can do a quick test for hydrocarbons in the coolant.
Glenn
Old Mar 3, 2005 | 03:42 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: overheating issue (NJIN BUILDR)
Oil in water?
Water in oil?
Have you flushed your cooling system lately? How old is your water pump?
Old Mar 3, 2005 | 04:13 PM
decible01's Avatar
Default Re: overheating issue (LSVTEC 91 Civic)
no oil in water. I'll check for water in the oil. its not burning coolant. the engine is out of a 94. I'm guessing the waterpump is the same. engine has roughly 90,000. head gasket wouldn't explain the fluctuations in heater temp.......
shogun1552
Feb 12, 2013 07:38 PM
tech410
15
Sep 22, 2010 05:22 AM
decible01
Mar 3, 2005 04:41 PM
forksports
Jan 17, 2004 09:32 AM
blackgrrl23
10
Dec 20, 2003 03:56 PM
