Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
1/8th Toe Out - What's that in Degrees?
Old Mar 3, 2005 | 10:40 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default 1/8th Toe Out - What's that in Degrees?
I'm doing an alignment for s customer here at the shop, and he is asking for 1/8th toe out up front - how do I translate that into degress as measured by my Hunter alignemtn machine?
My machine will tell me +.0x or -.0x with x being a number, so I'm trying to get the equivalent of 1/8 toe out.
Thanks in advance.
Old Mar 3, 2005 | 10:46 AM
mstewar's Avatar
Default Re: 1/8th Toe Out - What's that in Degrees? (B18C5-EH2)
search is your friend..
but here's the formula to convert:
toe in inches = (tan x) * tire diameter where x is the degrees..
if i remember my trig correctly, that would make:
toe in degrees = (tan^-1 (toe in inches/tire diameter))
the first part is right.. the second part(my math) may be wrong, someone correct me if it is..
on my car, it roughly works out to -.22 degrees total, 1/16th on each side is about -.11 on each side..
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: 1/8th Toe Out - What's that in Degrees? (mstewar)
Thanks very much, that was quick.
Onto that alignment now, thanks.
Old Mar 3, 2005 | 11:31 AM
Chris F's Avatar
https://honda-tech.com/zerothread?id=1061318
soh cah toa
EDIT: Google calculator to the rescue: Assume tires are 23.5" in diameter.
Google arcsin(.125/23.5) in degrees
You get arcsin(.125 / 23.5) = 0.304766222 degrees
http://www.google.com/search?s...grees
Old Mar 3, 2005 | 11:34 AM
mstewar's Avatar
Default Re: 1/8th Toe Out - What's that in Degrees? (Chris F)
ITR forum > RR/AX forum.. I had searched a couple months ago and got my formula out of here..
Old Mar 3, 2005 | 01:21 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">ITR forum &gt; RR/AX forum.. I had searched a couple months ago and got my formula out of here.. </TD></TR></TABLE>
Arctan vs. Arcsin give the same number for small angles... it just depends on if you put the right angle to the tire or the right angle to the centerline of the car (I used centerline of the car).
In this case the diff in arctan(.125/23.5) in degrees vs. arcsin(.125/23.5) in degrees is 0.3047619 vs. 0.30476622.
What did you use for tire diameter?
Anyhow, an eighth TOTAL toe out is .3 degrees, or .15 on each side. YMMV, IANAL. I asked an alignment shop for xyz degrees total toe out in front (even wrote it down for them) and they put xyz degrees on EACH SIDE. Bastards.
-Chris
Old Mar 3, 2005 | 01:24 PM
mstewar's Avatar
I used 22 inches for my tire diameter..
I assume you're using different tires than I, hence the 1.5" difference..
Old Mar 3, 2005 | 04:59 PM
LX4CYL's Avatar
Does the Hunter alignment machine not have the ability to display toe in inches? Last time I got mine done on a Hunter machine it did...
Old Mar 3, 2005 | 08:30 PM
TeamSlowdotOrg's Avatar
what 22" tire are you using? All the 205, 225 15's and such are just under 23" or taller.
Old Mar 3, 2005 | 10:36 PM
mstewar's Avatar
Default Re: 1/8th Toe Out - What's that in Degrees? (TeamSlowdotOrg)
it was on some very bald azenis.. and I'm sure there was a bit of error involved..
i'll actually be redoing the alignment tomorrow the old fashioned way(no machine) on my R compounds..
Old Mar 4, 2005 | 06:10 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">it was on some very bald azenis.. and I'm sure there was a bit of error involved..
i'll actually be redoing the alignment tomorrow the old fashioned way(no machine) on my R compounds..</TD></TR></TABLE>
[threadjack]
Which old-fashioned way?
[/threadjack]
Old Mar 4, 2005 | 07:06 AM
mstewar's Avatar
not using a machine..
plates and strings/measuring tapes
Old Mar 4, 2005 | 07:28 AM
Todd00's Avatar
I said I don't want a title!
What would be really nice is if someone would do a flash card for this. Give a range of popular tire diameters and under that what each degree works out to be in inches.
Then RR/AX &gt; ITR Forum
Old Mar 4, 2005 | 07:58 AM
Chris F's Avatar
Default Re: 1/8th Toe Out - What's that in Degrees? (Todd00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Then RR/AX &gt; ITR Forum </TD></TR></TABLE>
Old Mar 4, 2005 | 08:03 AM
Todd00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Nice
That's per side and not total, correct?
Old Mar 4, 2005 | 08:10 AM
trutuner's Avatar
no 16" love?
Old Mar 4, 2005 | 08:13 AM
Chris F's Avatar
Default Re: 1/8th Toe Out - What's that in Degrees? (trutuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trutuner &raquo;</TD></TR><TR><TD CLASS="quote">no 16" love?</TD></TR></TABLE>
I have 16" streets and snow tires. Never never again, tire selection sucks.
Just use 23" for 205/45R16, 23.5" for 215/45R16, 24" for 205/50R16
-Chris
Todd00's Avatar
Rim size does not matter. What you are looking for is overall *tire* diameter.
kelvinchau25
Jan 15, 2008 01:14 PM
kcem1
Suspension & Brakes
Dec 15, 2005 01:48 PM
accordredliner
Oct 3, 2005 04:57 AM
ion_four
Jun 23, 2004 06:00 AM
