car not starting?
Old Mar 2, 2005 | 08:38 PM
XpLiZiT's Avatar
Default car not starting?
so the problem is that every once in awhile i put in the key and try to start the car but it wont. all i hear is a sort of low hummm from what i think is the battery? and nothing from what u usually hear from when u start the car (not sure if that makes sense) and most of the time it will start if i take out the key or push the button on the alarm (which isnt even hooked up) any ideas on what the problem is?
Old Mar 2, 2005 | 08:44 PM
Spade's Avatar
Default Re: car not starting? (XpLiZiT)
low quite hum? Sounds like the fuel pump to me.
Can you hear it when you first turn the key to on and not start as well? If so that is the fuel pump.
If not, it seems as though it may be your kill switch in the alarm is starting to malfunction.
Old Mar 3, 2005 | 06:21 PM
XpLiZiT's Avatar
Default Re: car not starting? (Spade)
dayam this is really startin to bug me... and the problem got sorta worse as when i was driving around, when i came to a complete stop the car just turned off and the engine sounds like its goin to turn off any ideas of what the problem could be now?
Old Mar 3, 2005 | 06:26 PM
SDT Project EF's Avatar
Check you battery. You might want to replace you cap and rotor on your distributor. Also check your grounds maybe add some. Good luck hope you get it resolved.
Old Feb 11, 2014 | 03:31 PM
wnp94's Avatar
did you find out what it was?
Old Feb 11, 2014 | 05:20 PM
Ross 2.0's Avatar
In a Junkyard near you.
Did you really bump a 9 year old thread...
Greeno56
Honda Civic (2006 - 2015)
Dec 28, 2015 10:51 AM
tran1088
Acura TSX
Jan 19, 2012 11:51 AM
Boostedb20EH2
20
Feb 28, 2008 07:23 AM
CodyC142
Mar 19, 2007 12:45 PM
dumbchild
Sep 4, 2002 10:52 AM
