Weird starter problem
Old 02-09-2008, 12:25 PM
Boostedb20EH2's Avatar
Default Weird starter problem
Okay, Well my hatch burns alot of oil, because of a piston problem that needs rebuilt. The guy who is going to rebuild my engine doesn't want to start on my car yet though because I have a starter problem, And he doesn't want to rebuild it without being able to start it up.
So whenever I turn the key, the fuel pump does not prime, and when I try to start the car up it makes a crazy clicking sound really quickly and the lights on the dash flutter with it, but it will not start. My buddy and I have switched the main relay out and nothing, I don't have a clue what this could be. Anyone have any idea?
Oh and whenever it does that it completely drains the battery. So you have to try and start it with the jumper cables on.
Old 02-09-2008, 02:46 PM
boosted_EM1's Avatar
Default Re: Weird starter problem (Boostedb20EH2)
ttt for some help
Old 02-09-2008, 02:52 PM
nub
nub's Avatar
Default Re: Weird starter problem (boosted_EM1)
sounds like a bad battery to me
z6hatchboy's Avatar
Sounds like a ground issue to me. Check your grounds and negative terminal, after that it the problem persist, you may check the alternator. I dont know however why the pump isnt priming, have you tried to do the jumper wire thing at the relay connection that they mention in the haynes manuals? If not that, possibly a fuse or wiring?
Old 02-09-2008, 03:16 PM
nub
nub's Avatar
Default Re: Weird starter problem (z6hatchboy)
does the car start if you jump it with cables? if yes, you either have a bad battery or a fault in the charging system. if no, check your engine grounds.
Old 02-09-2008, 03:32 PM
z6hatchboy's Avatar
Default Re: Weird starter problem (nub)
A fault in the charging system could be a bad/loose ground.
Old 02-09-2008, 03:46 PM
nub
nub's Avatar
true dat,could be several things- bad ground,altenator,blown charging system fuse,no altenator belt, blah blah blah
Old 02-09-2008, 09:42 PM
Already switched the battery, How many grounds are there, and list them. Im thinking its a bad ground possibly?
Old 02-10-2008, 11:01 AM
Bump for some help please.
Old 02-11-2008, 11:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Bump for some help please.</TD></TR></TABLE>
Old 02-13-2008, 12:37 PM
Please?
Old 02-13-2008, 12:54 PM
almaxximo's Avatar
it needs a battery duh!!!
Old 02-13-2008, 01:01 PM
Default Re: Weird starter problem (almaxximo)
Lol, already put on in. duh..?
Old 02-13-2008, 01:42 PM
nub
nub's Avatar
battery neg. thermostat housing valve cover or cylider head to core support trans to pass frame
Old 02-13-2008, 01:58 PM
thanks they are all good except I cant find the thermostat one to check it. Any other possible solutions other than a ground?
Old 02-27-2008, 08:28 AM
steviethekidd's Avatar
my car is doing the same thing with the clicking thing, ill post if i find out what it is, it did it this morning right before work
Old 02-27-2008, 10:05 AM
Blk00EJ8's Avatar
Default Re: (steviethekidd)
The clicking sound is the sound of the starter secondary solenoid being energized but because the engine isn't turning over, the primary solenoid isn't engaging. Therefore, I'm going to say the battery is mostly discharged.
Old 02-27-2008, 03:50 PM
Default Re: (Blk00EJ8)
It was indeed a loose battery connection
on me.. Looked everywhere and the simplist solution was it.
Old 02-27-2008, 04:12 PM
1992Si's Avatar
I guess you learned a lesson...
Old 02-27-2008, 05:41 PM
Default Re: (1992Si)
I guess?
Old 02-28-2008, 07:23 AM
Blk00EJ8's Avatar
Default Re: (Boostedb20EH2)
Well that's good you figured it out. The fast clicking sound is generally an indication that battery power is insufficient to even start cranking the engine over.
BigChina
13
09-05-2008 08:58 AM
laziebun
04-24-2008 11:10 AM
Slow as piss
08-15-2006 05:08 AM
Arsenal
08-01-2006 10:57 AM
raymas8
10
07-29-2005 04:50 PM
Quick Reply: Weird starter problem
