Integra GS-R pple
Can you feel the VTEC kick in? u know, like push u back in your seat? i test drove a 94 gsr and could not feel it. maybe sonthing wrong w. the solenoid.. let me know, THANKS!
the power curve of a GSR is quite linear, so you won't really feel a "surge". However the needle keeps pulling hard right up until 7600 rpms. If you want to feel a non-turbo surge, ride in the celica gts.
you wont really feel a kick. like someone said earlier the secondary runners opening up causes a bigger kick than vtec, also after vtec engages it will pull harder all the way to redline. below vtec =
surge smurge, smooth engagement is where its at
Not having a "surge" is a good thing, especially when you're at the track.
Whenever i see a celica GTS dyno chart, i see a huge surge when vvtl-i kicks in. I don't see as much of a surge on an ITR chart. But then again, each car varies. I have just heard that GTS vvtl-i is very noticeable because the car makes crappy power before it, which is why it is criticle you land on that second cam for your next shift.
I rather have a useable midrange. If you want a surge (i don't know why though), get a v-afc, and raise the switch over to 6000 rpms with stock cams. You'd lose a chunk of midrange.
