vtec on poor mans
Old Dec 18, 2006 | 08:41 AM
94whitegsi's Avatar
Default vtec on poor mans
is the vtec on the poor mans, going to be louder then the gsr or wat...
Old Dec 18, 2006 | 08:53 AM
b16vtech's Avatar
Default Re: vtec on poor mans (97redtegra)
or wat...
Why is everyone obsessed with loud vtec.... if you want loud vtec buy an exhaust flow controller and when vtec hits pull it wide open. Loud vtec does nothing and its a sign of a worn down motor. Chances are if its a poor mans type r its been ran the hell out of so you are probably going to have "loud VTAK"
Old Dec 18, 2006 | 08:59 AM
94whitegsi's Avatar
Default Re: vtec on poor mans (b16vtech)
well i guess i ask the quesiton wrong ... what i was asking is it going to pull harder then a gsr when vtec kicks in??
Old Dec 18, 2006 | 09:23 AM
b16vtech's Avatar
I would hope a "type-r" motor would pull harder than a gsr considering they have more power. Then again it all depends on the car. My car doesn't feel like it pulls at all. If you rode in it and closed your eyes you would think it was the slowest thing alive but somehow I pull off 13 second ET's
Old Dec 18, 2006 | 09:25 AM
ac_attak's Avatar
What exactly are you doing to make a poor mans type r?
Old Dec 18, 2006 | 09:30 AM
b16vtech's Avatar
Default Re: vtec on poor mans (ac_attak)
I assumed he was doing what everyone else does pr3 head gsr block and type r internals
Old Dec 18, 2006 | 09:36 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16vtech &raquo;</TD></TR><TR><TD CLASS="quote">I assumed he was doing what everyone else does pr3 head gsr block and type r internals</TD></TR></TABLE>
Sadly many people think that a stock B16 head and ITR cams on a stock GSR block = poor mans type R. They somehow forget about the valves, valvesprings, intake manifold, throttle body, raised compression, P&P work, and ECU.
Old Dec 18, 2006 | 10:12 AM
94whitegsi's Avatar
Default Re: vtec on poor mans (95 integra)
its a jdm b16 head with skunk 2 stage 1 cams with honda s200 on stock gsr block
Old Dec 18, 2006 | 10:32 AM
95 integra's Avatar
which is not really a poor mans type R. That term now apparently just means something to do with a PR3 head and GSR block....could be built with a turbo, its still a PMTR.....atleast thats the majority rule (not my personal opinion).
Old Dec 18, 2006 | 12:46 PM
RS'R''s Avatar
probably wouldnt be a 'poor mans' type r if it were built to full type r specs, ye?
some people just bolt on a stock b16 head on a gsr block and call it a day. i guess it makes a good low compression engine for boosting... but to answer the OPs question no, the poor mans type r is not going to have louder VTEC than your stock B18C1.
but if you really want people to know you've hit VTAK, hook up a big neon VTEC sign to your VTEC solenoid Wouldn't that work?
Old Dec 18, 2006 | 12:51 PM
Topher.'s Avatar
To answer your question......It will <U>most likely</U> pull harder than a stock GSR motor......but it won't really pull much harder than a GSR with the same cams and an intake manifold as well as some tuning (s200)
Old Dec 18, 2006 | 04:40 PM
ac_attak's Avatar
Wont you lose compression using a b16 head on a gsr block, making it slower?
I think you should go with ctr pistons if you are using the b16 head.
TastyDragon
Oct 25, 2006 04:12 PM
J's GS-R
Feb 21, 2006 09:13 PM
shyboi4u
Oct 7, 2005 11:54 PM
White S2k
11
Oct 30, 2002 11:07 PM
JDMchris
May 20, 2002 11:46 AM
