Question about my oil pressure making sssshhh noise.
Ok so I've had my B16 now for about 6 months and recently when I pull out the dipstick it makes this ssshh noise (as stupid as it sounds, its like a blowoff valve). It just started doing this recently. I don't know if its normal or not. Should I be concerned?
stock B16 with I/E changed the oil every 2500miles on Mobil 1 synthetic.
When you pull the dipstick like actually out of the hole it makes that noise? WTF..
The only thing that comes to mind might be a little bit of pressure but i'm not sure if that would make a b.o.v noise...
So it is when u actually pull the dip out of the hole right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Whats your oil level at when the car isnt running?</TD></TR></TABLE>
first time i noticed i was inbetween the holes. i topped it off and its still ssshhing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgejetson »</TD></TR><TR><TD CLASS="quote">Turn your car off first</TD></TR></TABLE>
i did on and off and it still did it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">stock B16 with I/E changed the oil every 2500miles on Mobil 1 synthetic.</TD></TR></TABLE>
Holy waste of money batman...
Don't know why you dipstick is holding pressure but you are changing oil way too much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btran »</TD></TR><TR><TD CLASS="quote">cool ...you got a built-in mini-turbo...
Honda secretly add this to several car ...
bump</TD></TR></TABLE>
really? too bad its still torqueless and slow.
so noone knows?
so noone knows?
Lets think...what would cause pressure to build up in the crankcase/oil pan area?
PCV valve clogged up...that's the best thing I can come up with.
Did you search the archives?
thephilosopher
Transmission & Drivetrain
May 30, 2013 03:13 PM
Go_Race_Your_Self
Jun 19, 2011 11:03 AM
