Turn my motor off and a scrapping sound?
Old Mar 2, 2005 | 02:30 PM
InTeGrA B18b1's Avatar
Default Turn my motor off and a scrapping sound?
Turn my motor off and a scrapping sound, everytime i turn it off sounds like something is scrapping under my hood like metal. any1 got an idea about what it could be?
Old Mar 2, 2005 | 02:48 PM
BuyImports2's Avatar
have you tried lifting up the hood, then having someone turn the car off while you are watching the engine? that might help you localize the problem.
Old Mar 2, 2005 | 05:32 PM
Carnage R1's Avatar
Default Re: (BuyImports2)
spun bearings?
Old Mar 2, 2005 | 06:19 PM
Bay_707's Avatar
rocker arms?
Old Mar 2, 2005 | 06:20 PM
PLAGUED_DB7's Avatar
Default Re: (Bay_707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM DC2 Monkey &raquo;</TD></TR><TR><TD CLASS="quote">spun bearings?</TD></TR></TABLE>
thats what I was thinking..does it make the sound when you start up in the am??
Old Mar 2, 2005 | 07:12 PM
ernald711's Avatar
Default Re: (PLAGUED_DB7)
i installed my motor with no a/c belt. the a/c pulley was rubbing against another one.... at first i thought it was a leak in my gasket from the TB to the mani. anyways to fix it, i just released the tension raised the pulley up and tightened her down... problem fixed... hope it's just as easy as that.
added: it was pretty consistant then after i'd turn her off the sound would run down(get quieter and softer), until it was off.
Modified by ernald711 at 9:32 AM 3/6/2005
Old Mar 3, 2005 | 09:19 AM
Default Re: (ernald711)
starts up fine, Some times i think it is my alternator belt but would a belt make a scrapping noise? Usually when i turn my car off i can hear the air coming out from the intake. But not i hear a scrapping, I guess when i get home i will try narrowing it down. thanks for you help. I hope there is no big problems.
Old Mar 3, 2005 | 11:16 AM
redINTEGRAdriver's Avatar
Default Re: (InTeGrA B18b1)
it could be the alternator
Old Mar 4, 2005 | 04:37 PM
lke2drvgsr's Avatar
Default Re: (JDM DC2 Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bay_707 &raquo;</TD></TR><TR><TD CLASS="quote">rocker arms?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redINTEGRAdriver &raquo;</TD></TR><TR><TD CLASS="quote">it could be the alternator</TD></TR></TABLE>
lmao wow, what random guesses, that point to absolutely nothing.. might as well be saying it's the cd player or something
where is the scraping noise come from? is it high pitched, or low pitched? does the sound slow down as the motor shuts off, or is it a constant sound? is the only time youve heard it when you shut off your motor? have a friend help you to pinpoint it.
uses0ap
Apr 11, 2008 10:19 AM
...rohit
Honda Motorcycles
Jul 8, 2007 08:55 AM
cutzmansi
Sep 13, 2004 01:14 PM
josh green
Sep 11, 2004 08:12 AM
VTECJUN
16
May 17, 2004 09:22 PM
