ignition switch getting sticky, what to do?
Old Mar 2, 2005 | 02:10 PM
carnifex's Avatar
Default ignition switch getting sticky, what to do?
on a 94 teg my ignition switch is hard as hell to get the key turned back to get it out. can you lube it to make it easier? what do you use? thanks. jim.
Old Mar 3, 2005 | 12:14 PM
carnifex's Avatar
Default Re: ignition switch getting sticky, what to do? (carnifex)
bump
Old Mar 3, 2005 | 01:26 PM
3.504's Avatar
you could possibly have a key that wasn't the original key. but if it feels sticky you could try putting some wd40 on your key and slide it in and out of the switch and turning the switch a bunch of time. you could also have the steering wheel cocked, try turning the steering wheel in either direction as you try to get the key out. if that all doesn't work, have a key made at acura using your vin and title.
Barf Hat
Oct 9, 2019 05:45 AM
phillbo
Jan 20, 2007 09:48 AM
dieselgg
Sep 17, 2006 06:55 PM
Itzmy91Teg
Jun 29, 2006 08:24 PM
wolfen
Acura TL, RL & ZDX
Jul 17, 2004 06:16 PM
