Question about Oil in Cylinder Head
Old Mar 2, 2005 | 12:09 PM
EJ2-Fluffy's Avatar
Default Question about Oil in Cylinder Head
Also, my D16a6 has no knock sensor (unless that is the oil pressure sensor) on the block for my OBD-1 Computer to hook up to.
Thanks in advance,
Jon
Old Mar 2, 2005 | 12:44 PM
fourthgenhatchB17's Avatar
Default Re: Question about Oil in Cylinder Head (CRX-Fluffy)
U should use a obd-1 P28, if u do that, u dont need a knock sensor. About the "oil supply", are u doing a mini me? If so, just bolt the head on the A6 block and thats pretty much it. Do a search on it man.
Old Mar 2, 2005 | 03:38 PM
crxnj's Avatar
Default Re: Question about Oil in Cylinder Head (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote"> If so, just bolt the head on the A6 block and thats pretty much it. Do a search on it man.</TD></TR></TABLE>
You have to remove the oiljet from the block because the d16z6 head already has one..If you dont take out the jet on the block you wont have vtec,,And thats the whole point of a mini-mi..To have vtec
What obd1 ecu do you have that requires a knock sensor??,,
Get a p28 to run it best
Old Mar 2, 2005 | 03:40 PM
Default Re: Question about Oil in Cylinder Head (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
You have to remove the oiljet from the block because the d16z6 head already has one..If you dont take out the jet on the block you wont have vtec,,And thats the whole point of a mini-mi..To have vtec</TD></TR></TABLE>
Hey he was suppost to find that out if he searched. I wonder how many 1000's of threads have said this already.
Old Mar 2, 2005 | 08:47 PM
EJ2-Fluffy's Avatar
For your information, that isn't the oil jet. That picture i posted up has to do with the rocker arm assembly. There seems to be a threaded hole on the distributor side of the rocker arms.
Yes I am doing a mini-me consisting of a Z6 head on an A6 Block. As for the knock sensor, I figured out what it went to. (seeing I have an a6 block and I am using a P28 ecu thanks) I have all the vacuum hoses connected on the intake manifold.
All I was asking (since I wasn't very clear) is there a bolt which goes into that threaded section on the assembly? (It has nothing to do with the oil squirter found on the block)
Thanks again for your time,
Jon
Old Mar 2, 2005 | 08:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">For your information, that isn't the oil jet. </TD></TR></TABLE>
We know. About the "knock sensor," there isnt one on the block. You must be getting it confused with something else.
BUMP for the threaded bolt hole question, i dont mess with sohc's.
Old Mar 2, 2005 | 09:04 PM
EJ2-Fluffy's Avatar
Thanks I figued the knock sensor out. Just want to know what goes in the threaded section of the rocker arm assembly.
PLEASE LOOK AT THE PICTURE BEFORE POSTING
Thanks again,
Jon
Old Mar 2, 2005 | 09:59 PM
djsgtrip's Avatar
There should be a bolt that goes there.
Old Mar 3, 2005 | 03:34 AM
crxnj's Avatar
Yeah,,Should be a bolt in there,,
Look at this pic
Old Mar 3, 2005 | 05:38 AM
EJ2-Fluffy's Avatar
Sweet, can you get a close up of the bolt. I just want to see if I can pick up one from the yard or from someone on the board. That is exactly what I was looking for
Or you think im better off just putting any bolt in there.
-Jon
Old Mar 3, 2005 | 05:46 AM
EJ2-Fluffy's Avatar
Anyone have an idea of the name of the bolt? So I can look it up in Helms correctly?
Old Mar 3, 2005 | 05:59 AM
altoid's Avatar
looks like a 12mmx10x1.25...in other words pick up any 12mm honda bolt you have and hand tighten it so you know it fits and then hit it with a rachet.
Old Mar 3, 2005 | 06:00 AM
EJ2-Fluffy's Avatar
Default Re: Question about Oil in Cylinder Head (altoid)
sweet, ill do that Anyone happen to know what its for however?
Old Mar 3, 2005 | 07:05 AM
EJ2-Fluffy's Avatar
anyone?
Old Mar 4, 2005 | 06:25 AM
altoid's Avatar
muh bad looks like a 14mm...i belive its to hold the cam down, but its been forever since i mingled with a head. take it apart and find out
Old Mar 4, 2005 | 06:28 AM
EJ2-Fluffy's Avatar
Well i found the bolt, looks like all the other headbolts but its in a small head with a larger diameter bolt about 1/2" long. I don't think its to hold down the cam, it seems like it plug sup a chamber that is in the head. Maybe its for testing purposes? Haha.
Thanks again to all those who replied. It helped me alot!
Jon
krysted9354
Dec 28, 2008 12:43 PM
imaginespyders
Oct 1, 2007 06:48 AM
4theluvofhonda
Feb 11, 2007 02:26 PM
slowteg550
Jun 27, 2006 04:35 PM
Si Shane
Aug 2, 2005 05:41 AM
