Advice on using a d15 block with a d16 head???
PLEASE HELP: I need Advice on using a d15b7 block with a d16y8 head???
For temporary purposes till I get my new motor I am using a d16y8 head on a d15b7 block. Is there any huge differences in the motors that I need to know about/modify??
The d15b7 block doesn't have a knock sensor, do I need the knock sensor? What can I do?
And any tips on easier ways to remove axle and tranny to take out the d16 block???
Modified by 4theluvofhonda at 10:49 AM 2/11/2007
Re: PLEASE HELP: I need Advice on using a d15b7 block with a d16y8 head??? (4theluvofhonda)
they would fit, but Z6 head would be better chiose...
yes, you need a knock sensor, 'cause the VTEC is predefined and will mostly rely on knock sensor!
you also need a solenoid switch for VTEC...and a P28 with VTEC wires, or you'll have to pull some wires from the engine compartment to the ECU...
btw, if you plan to put the Y8 engine which is OBD2 ECU&wires to 5gen civic which is OBD1 ECU&wires, you will have problems...but there are some text on this forum to help you...so try the search!
Re: PLEASE HELP: I need Advice on using a d15b7 block with a d16y8 head??? (KLiK)
what parts do i need to buy to make this combo work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KLiK »</TD></TR><TR><TD CLASS="quote">they would fit, but Z6 head would be better chiose...
</TD></TR></TABLE> Since when does a OBD-1 SOHC require a Knock sensor, not one of my Z6's has ever had one, nor required one to function properly.
my car came stock with the d16y8 vtec, will i still need the ecu, vtec wires, and vtec switch, or will i already have that?
Re: PLEASE HELP: I need Advice on using a d15b7 block with a d16y8 head??? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Since when does a OBD-1 SOHC require a Knock sensor, not one of my Z6's has ever had one, nor required one to function properly.</TD></TR></TABLE>
He was talking about my y8 not the z6, he only referred to the z6 because he said it would be a better choice for the combo with the d15b7 block
Argentinakidd
05-15-2018 05:49 PM
john'sD16Aek
15
05-01-2013 02:25 PM
Littleredsi
05-30-2004 10:06 AM
EK_vzla
02-03-2004 07:53 AM
