GSR Tranny Problem
Old Mar 2, 2005 | 09:40 AM
93civiconair's Avatar
Default GSR Tranny Problem
Ok Im getting ready to buy a complete Gsr swap. Im getting a pretty good deal on the motor because im getting it from a friend. Right now its in his Del Sol and I was driving it the other night and I noticed that it scraped when I put it into 5th gear. He told me it also scraps going into 4th at high Rpm. Is this a really big problem that needs to be fixed right away. Also does anybody know about how much its going to cost to fix it. Thanks for the help.
Old Mar 2, 2005 | 10:00 AM
NRN GT4's Avatar
Default Re: GSR Tranny Problem (93civiconair)
It most likely is synchros or shift forks starting to go. I can be a variety of other things also. Does he have a short shifter? This can play a role as the driver may be trying to shift faster than the tranny will allow. /
I would be concerned with a transmission in this kind of condition usually its an indicator that the engine and trans have been abused in this case sounds like highway racing to me.
Still depending on the age of the motor and the fact it would actually be a gsr is a very good find regardless of tranny problems. Just be sure to know what is happening up front ie take the drain plug out and check for shavings ect, and i would def do a compression check on the motor first before even discussing a sale. good luck
Old Mar 2, 2005 | 02:31 PM
PrettyLude's Avatar
it sounds like your synchros are going bad, to fix the tranny would be more expensive than to buy another used one
sr20cars
Transmission & Drivetrain
Sep 23, 2011 08:41 AM
kanaboy
Oct 12, 2009 11:04 PM
zachv365
16
Apr 29, 2009 07:18 PM
SPOOLINmatt
Oct 21, 2007 04:30 AM
davidluko
Mar 9, 2007 03:59 AM
