100,000 mile ITR compression numbers
Old Jan 21, 2002 | 11:39 AM
ZygSpeed's Avatar
Default 100,000 mile ITR compression numbers
Hi guys,
Just got back from Ben Schaeffer's minutes ago.
Did my 100,000 mile service (valve adj, rotor, cap, etc ...alread has new timing belt), installed front mugen bar, and finally got around to checking the compression.
Numbers were all on the order of: 225-210
(225, 215, 210, 215) cylinders 4, 3, 2, 1
I'm quite happy with these numbers, ... Ben was expecting to see 180's!
Mobil 1 baby!!
Old Jan 21, 2002 | 12:08 PM
BudMan's Avatar
Default Re: 100,000 mile ITR compression numbers (zygspeed)
'98 B18C5 (79,000 miles)
<U>Cyl1</U> <U>Cyl2</U><U>Cyl3</U><U>Cyl4</U>
236228232235{with Cam Gears adj}
221218220225{w Cam Gears at stock setting}
Nice to see mine shouldn't drop tooooo much in the next 21,000 miles
Nice job Ed!! {aka: "tailout" - Deal's Gap oversteer king}
BudMan Mobil 1!!!
Old Jan 21, 2002 | 12:12 PM
B18CXr's Avatar
Proof that Honda's aren't crap, Ed HAS beat the chit out of his car and she still purrs.
Old Jan 21, 2002 | 12:14 PM
ZygSpeed's Avatar
Default Re: 100,000 mile ITR compression numbers (BudMan)
Jeff, first of all ... nice numbers!
Someone gave me a fender ding (my first "good" ding ), on the front fender just where Ferraris have that yellow prancing horse emblem, it buffed out ok but still left an indentation ... so I put the Deal's Gap yellow triangle emblem there! Looks pretty good, actually. I figure that's just about where the oncoming vehicle would have hit me.
Hopefully I've "fixed" that tail-out (oversteer) problem by installing the Mugen front sway bar to balance out the rear one.
[Modified by zygspeed, 4:34 PM 1/21/2002]
Old Jan 21, 2002 | 12:22 PM
BudMan's Avatar
Hmmmmm - now I know how you were inducing that soooo easily. Wes (white dragon) was just here yesterday & that was the topic of discussion since that was the first time I saw you - doing tail out around the curve while Tony was getting car sick ....
Good idea with the sticker {first good use I've heard of actually }
Old Jan 21, 2002 | 12:23 PM
Back in Black's Avatar
Rather OG
all i have to say is...damn!
Old Jan 21, 2002 | 12:42 PM
ZygSpeed's Avatar
Default Re: 100,000 mile ITR compression numbers (darth vadeR)
One last note, since the motor was warm we did the compression check before the valves were adjusted.
Old Jan 21, 2002 | 12:54 PM
BudMan's Avatar
were your valves off much? that could definately increase your numbers up to mine if they were
I sent you an IM ed...
Old Jan 21, 2002 | 01:09 PM
ZygSpeed's Avatar
Yeah, take that ... George!
All that smoke apparently was just too much fuel!
Old Jan 21, 2002 | 01:18 PM
ITRbroham's Avatar
shit post warrior
Hey Ed, when do plan on puttin that motor to rest? 200k?
Old Jan 21, 2002 | 01:27 PM
ZygSpeed's Avatar
Default Re: 100,000 mile ITR compression numbers (ITRbroham)
Probably after my turbo kills it (or when I can afford a rebuild/update, whichever comes first).
Lloyd, 200K would be nice, but I'm afraid I'm too impatient for that.
Then again, it's my daily driver till I decide what to do with my CRX(s).
Old Jan 21, 2002 | 01:33 PM
ITRbroham's Avatar
shit post warrior
I didnt know you went turbo....how long have you had it?
A 97 ITR with a 2k spec motor....now that would be awesome! Good luck Ed!
Old Jan 21, 2002 | 02:11 PM
ZygSpeed's Avatar
I bought the "kit" from Jack (B18CXr) at the expo last year, but it's still not installed.
Maybe I need to practice on my CRXs, first!
Old Jan 22, 2002 | 06:08 PM
B2FiNiTY's Avatar
Nice numbers! Hopefully I'll be able to see the 100k one day. Maybe even the 200k mark.
Old Jan 22, 2002 | 06:43 PM
1GreyTeg's Avatar
Wow, great to hear.
My 94 Ls had 136,000 on it before I sold it and it still ran strong. I don't have the compression numbers but I felt very confident with it when I sold it. Ya know what? The guy, "a friend I sold it to" resold it after another 2 years of less than nice treatment and as far as I know it's still running.
I'm curious just how much shorter the R's lifespan is than the average GSR, with average use and proper service of course? There is sentiment that it will fail earlier than most other Acura's and Honda's. I'd like mine to proove that belief wrong like his is...
A.
Old Jan 22, 2002 | 08:13 PM
EPGONZALEZ's Avatar
Default Re: 100,000 mile ITR compression numbers (1GreyTeg)
ED- you are my hero! i cant wait to hit the 100,000 mile mark in mine!
ep-who has only 94,000 miles to go....hehehe
Old Jan 22, 2002 | 09:45 PM
EGtoR's Avatar
Default Re: 100,000 mile ITR compression numbers (EPGONZALEZ)
The number look great.
Old Jan 23, 2002 | 04:24 AM
ZygSpeed's Avatar
Default Re: 100,000 mile ITR compression numbers (EGtoR)
Thanks again guys!
I was definately "pleased" with the numbers, and now with the suspension in better shape I'll have to see about doing another track day (VIR Speedtrials?).
My only down side is I'm still running a USDM DC 4-1 and stock b-pipe ....
[Modified by zygspeed, 1:40 PM 1/28/2002]
Old Jan 28, 2002 | 09:17 AM
iperez's Avatar
Budman, are your compression numbers stock or modified (pistons, thin head gasket, etc.) ?? I am getting 235 pretty much across the board with a Spoon 2-ply head gasket and an otherwise stock block and I wonder if I'm on target. Thanks !!
Old Jan 28, 2002 | 11:18 AM
BudMan's Avatar
Default Re: 100,000 mile ITR compression numbers (iperez)
I have not done anything more to the block other than cut the valve cover for access to cam timing gears. All stock internally, including gaskets.
I'm almost at 80,000 miles now. Hope that helps!
luckypon7
Jan 31, 2005 09:09 AM
Unsung
Dec 19, 2003 08:52 PM
95c1v1cs1
Dec 27, 2002 07:36 PM
Willard
Dec 11, 2002 06:53 AM
