Welding alternative...???
Old Mar 2, 2005 | 12:19 AM
integ22's Avatar
Default Welding alternative...???
Just curious and want opinions from you welders here about this product.....http://newtechnologyproducts.net/index.htm.
Would this be just as good for IC piping as welding?
Thanks,
John
Old Mar 2, 2005 | 05:09 AM
david@didrace.com's Avatar
Default Re: Welding alternative...??? (integ22)
They are brazing rods. Welding is stronger than brazing in most cases depending upon material thickness and joint configuration. For intercooler piping it would be fine though.
Old Mar 2, 2005 | 05:15 AM
Flashmn's Avatar
Default Re: Welding alternative...??? (backpurge)
I bet those are something close to techno-weld rods, which SUCK ***. They dont hold well, they're hard to braze with because you're using such a low heat that it doesnt tend to melt, then you noctice you've melted the base material. Tried the techno-weld rods, horrible. Took me 4 rods out of a 5 rod pack to make a catchcan, and it didnt even work out...
Old Mar 2, 2005 | 07:29 PM
Junglesnake's Avatar
I used JB Weld on all my intercooler piping that could not be seen....call me Ghetto, as I really do not care.
Old Mar 2, 2005 | 07:46 PM
dustin's Avatar
You need lots of heat to do actual brazing. Like oxy-acetylene type heat. If you have this much heat you could just weld hehe.
supafil25
Dec 18, 2009 11:02 AM
orangeturbogsr94
Aug 28, 2006 05:50 PM
VNTEC
Jan 6, 2004 04:58 PM
*Boostwerks*
Aug 20, 2003 06:22 AM
92HB_HB
Feb 13, 2002 02:13 PM
