What can i do about the O2 code i keep getting. Please make it stop.
Old Mar 1, 2005 | 11:06 PM
srv3fender's Avatar
Default What can i do about the O2 code i keep getting. Please make it stop.
Ok ive got an 88 crx hf with 91 si ecu and mpfi and d16y8/y7 with a 1 wire o2 sensor.
I keep getting the code 1 cel. But i cant find the car to be running bad.
I tried to unplug it to test it with a voltagemeter. But i sadly cant get the harness unplugged. how come they never put that **** in the manuals!
Now i know you guys are gonna say just switch to obd1.
Well i will but i wont be able to do it for a couple of months.
I just want to fix this problem so i can see if the ecu is throwing any other codes . cause it wont let me get past the code 1. Just keeps blinking about every 1-2 secs.
Old Mar 2, 2005 | 01:07 AM
srv3fender's Avatar
Default Re: What can i do about the O2 code i keep getting. Please make it stop. (srv3fender)
please help
Old Mar 2, 2005 | 04:11 AM
CRXCrazy123's Avatar
change the o2 sencer
Old Mar 2, 2005 | 07:19 AM
EP3_05's Avatar
If it was throwing more than one code you would know. It would go like this:
For example code 1 and code 8
(Blink pause 8 Blinks pause Blink pause 8 blinks) and it would keep repeating this pattern.
Just replace the O2 sensor and you should be ok.
Old Mar 2, 2005 | 08:38 PM
srv3fender's Avatar
Default Re: What can i do about the O2 code i keep getting. Please make it stop. (91civic)
well if it is throwin more than one code i wouldnt know because of the way it blinks
it doesnt keep a good beat. first blink is fast (the instant i turn on the car) then the gaps
are sometimes 1 sec sometimes 1 and 1/2 sec. Its confusing.
Anyway i could bypass the o2 (without a chip)
Plus, i cant get them damn thing unplugged from the harness. Anyone know how to do this. I know it sounds stupid
Old Mar 2, 2005 | 09:19 PM
srv3fender's Avatar
how much are they at autozone or the autozone clones
Old Mar 2, 2005 | 10:05 PM
DieMaster's Avatar
Needs to be About 20% Cooler
i think mine was like in the $30-40 range our one wire ones ore not expensive at all. it's the 4,5,6,7 wire ones that are in the couple hundred .
b18_crx
Oct 27, 2005 05:19 AM
DarkBB4
Aug 27, 2005 09:31 AM
srv3fender
Mar 2, 2005 09:19 PM
notfastenough
Nov 11, 2004 04:31 PM
00WhiteEKy
Aug 24, 2002 04:13 PM
