B17 tranny fit a b20b block?!?!?!
Old Mar 1, 2005 | 08:36 PM
jdm96dc2's Avatar
Default B17 tranny fit a b20b block?!?!?!
does anyone know if a b17 tranny will fit a b20 block...if so what do u got to do to make it work? do i got to have a ob1 harness, will 94-01 axles work for b17 tranny..whats the deal with this?
Modified by jdizzle00 at 9:51 PM 3/1/2005
Old Mar 2, 2005 | 08:00 AM
jarvis199's Avatar
Default Re: B17 tranny fit a b20b block?!?!?! (jdizzle00)
itll bolt up, but as far as axles id think u wouldnt have a problem using the gsr axles...
Old Mar 2, 2005 | 03:34 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdizzle00 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if a b17 tranny will fit a b20 block...if so what do u got to do to make it work? do i got to have a ob1 harness, will 94-01 axles work for b17 tranny..whats the deal with this?
Modified by jdizzle00 at 9:51 PM 3/1/2005</TD></TR></TABLE>
Yes....also, your axels have nothing to do with the wiring harness.
Old Mar 2, 2005 | 05:10 PM
Hybrid96EK's Avatar
The axles should work with no problem. ANY B series tranny will bolt up to ANY B series engine. Remember that, please, so we can avoid questions like this in the future. There is also no need to change the wiring harness because of the transmission you plan to use.
Old Mar 2, 2005 | 06:17 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdizzle00 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if a b17 tranny will fit a b20 block...if so what do u got to do to make it work?</TD></TR></TABLE>
Yes, nothing needed to make it work it will bolt right on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdizzle00 &raquo;</TD></TR><TR><TD CLASS="quote">will 94-01 axles work for b17 tranny..whats the deal with this?</TD></TR></TABLE>
If using 94-01 axles (driver's side axle and intermediate shaft is different than 90-93) you will need to use a 94-01 intermediate shaft as well. You will also need to change the driver's side tranny seal to a 94-01 seal.
Old Mar 2, 2005 | 06:19 PM
Default Re: B17 tranny fit a b20b block?!?!?! (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">ANY B series tranny will bolt up to ANY B series engine.</TD></TR></TABLE>
With the exception of the older Prelude B20's
mustang5.slow
18
Apr 17, 2007 09:15 PM
dohc_profile
Dec 19, 2006 08:35 PM
boostedcivic25
Oct 27, 2005 09:50 PM
jdm96dc2
Mar 1, 2005 08:57 PM
hellogoodbye
Apr 5, 2004 04:11 PM
