Gauge Lights Still Won't Turn On!!! Integra dash.
Old Mar 1, 2005 | 07:51 PM
litterbox's Avatar
I am a (Trial User) Army
Default Gauge Lights Still Won't Turn On!!! Integra dash.
Hey Guys,
Ok, here are the details. I've got a teg dash in the car now. I was using the civic dash harness and had the teg gauge cluster harness spliced to that. I plugged the dimmer plug into the civic dimmer switch, nothing happened. I plugged the dimmer plug into the teg dimmer switch, nothing happened.
Today, I wired in the actual integra harness. Again, I plugged in the dimmer plug to the dimmer switch and nothing happened.
I checked the fuse, and it's fine.
How do I bypass the dimmer switch all together? Which wires do I tap?
Thanks.
Old Mar 1, 2005 | 11:07 PM
litterbox's Avatar
Default Re: Gauge Lights Still Won't Turn On!!! Integra dash. (litterbox)
I'm in the dark here...
Old Mar 1, 2005 | 11:40 PM
BlueIntegraBoy's Avatar
Maybe all you bulbs are burnt. Make sure your splicing is correct.
Old Mar 1, 2005 | 11:42 PM
litterbox's Avatar
Default Re: Gauge Lights Still Won't Turn On!!! Integra dash. (BlueIntegraBoy)
I've been waiting for you to chime in. The wiring is correct. The gauge bulbs are not the problem either because they won't light up on the civic cluster either.
litterbox's Avatar
I'm using a 98-01 gauge cluster, and a 94-97 underdash harness.
Old Mar 2, 2005 | 12:11 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">I'm using a 98-01 gauge cluster, and a 94-97 underdash harness.</TD></TR></TABLE>
Would that make a difference?
xxjasonxx
Nov 20, 2008 06:08 PM
slamdacura
May 19, 2006 06:41 AM
snowblind7x
Apr 30, 2006 09:42 AM
GSR95DXHATCH92
Jul 26, 2005 01:33 PM
litterbox
13
Feb 12, 2005 06:05 AM
