h22a big problem please help
Old Mar 1, 2005 | 06:37 PM
del lude's Avatar
Default h22a big problem please help
h22 prelude disater « » 11:57 PM 2/22/2005 Reply Edit
hey whats up i have a 1995 honda prelude it has about 150 thousand miles and i went down to mayrland one night street racing it is about a 35 min drive well we got down there and went to a gas station where every body was hangin out then we left there i wasnt really pushin my car hard but then we left that gas station and went to a different spot and i thought we were going to stay so i turned my car off then we decided we r not so i started my car back up and i started to go and it made this noise like there was suming under the tire or the car a kinda loud noise sounded bad ne way i got out and there was nothing wrong so i got back in and started going eveything was fine then i got on the street and my vtec wouldnt pop it had stopped and the check engine light came on so we stopped and all my friends were looking at it n they didnt know what happen so i drove it back home vtec still not popping then next day i started it up looked at it it was kinda smokin black smoke well i checked the oil and it looks like there is metal shavings on the oil stick so its been parked for about 6 months and im bout to fix it but i dont know where to start im not how the metal shavings got there not sure if they r but im not sure where i need to start my cousin said i need get new valves cause they proably bent thats y the vtec is not pipping and the timeing belt skipped thats y it made that niose
let me know what u think it is
Old Mar 1, 2005 | 07:13 PM
Qfactor's Avatar
Default Re: h22a big problem please help (del lude)
sounds like you spun a rod bearing, if the shavings are in copper like color. time for a rebuilt.
Old Mar 1, 2005 | 07:44 PM
PrettyLude's Avatar
drop your pan and look at the bearings
Old Mar 3, 2005 | 07:56 AM
PURPLETERROR aka BIGMATT's Avatar
you prolly spun a rod or a main bearing, that would explain the metal shavings. it vtec not "popping" has nothing to do with bent valves, vtec runs off of oil pressure, and the ecu. start w pulling you codes, then start tearing things apart. also check you vtec selonoid gasket screen, its prolly plugged w shavings. good luck
Old Mar 3, 2005 | 08:25 AM
pontiac power's Avatar
Default Re: h22a big problem please help (PURPLETERROR)
yea vtec runs off the oil pressure, which you won't really have with spun bearings. I would start with pulling the motor and going from there,
Old Mar 3, 2005 | 06:32 PM
del lude's Avatar
Default Re: h22a big problem please help (pontiac power)
do u guys think it would be cheaper to just get a new motor for 1200 and use my tranny and ecu
Old Mar 4, 2005 | 09:51 AM
del lude's Avatar
where can i find the ecu codes for my car 1994 prelude
Old Mar 4, 2005 | 11:18 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del lude &raquo;</TD></TR><TR><TD CLASS="quote">where can i find the ecu codes for my car 1994 prelude</TD></TR></TABLE>
http://www.hondata.com
Old Mar 4, 2005 | 02:57 PM
del lude's Avatar
Default Re: h22a big problem please help (PrettyLude)
i couldnt find them and my dad said that its not a rod or main bearing cause the motor would of locked up and it still runs so what else could it b my brother said it might b the oil pump blew up
Old Mar 4, 2005 | 08:55 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del lude &raquo;</TD></TR><TR><TD CLASS="quote">i couldnt find them and my dad said that its not a rod or main bearing cause the motor would of locked up and it still runs so what else could it b my brother said it might b the oil pump blew up</TD></TR></TABLE>
that is not necessarily true, a spun bearing will still spin but it will make a nasty noise
Old Mar 5, 2005 | 01:26 PM
del lude's Avatar
the motor is not makin ne noise it sounds like it should run fine but it dosnt
Old Mar 10, 2005 | 05:02 PM
del lude's Avatar
im just going to change the motor and use my tranny motor for 1600 jdm
lovelove
32
Nov 27, 2009 12:03 AM
08SiFreak
Honda Civic (2006 - 2015)
Jul 31, 2009 04:43 PM
fridayfred3p
Dec 31, 2005 08:40 AM
