All motor lsvtec buildup
Old Mar 1, 2005 | 06:16 PM
JIDUM_Undercover's Avatar
Default All motor lsvtec buildup
Ok so i have a lsvtec motor im in the process of rebuilding. I just ordered ACL race series bearing kit. The regular sizes, the guy said some people run loose and u see more power but its less reliable so i stuck with reliable. I was going to order ARP Rod bolts but i dont know if i should go with the 8 mm or the 9 mm?? Which one would be better? And what would i have to do to put the 9mm in since they arent a stock diameter? Next is i have pr3 pistons going in on ls rods, which piston ring kit do i need to get? Just one for a b16 im assuming. And isint there a order or something for the piston rings to set like a gap or something? Please asnwer all the ?'s you can and if u cant dont post.
Old Mar 1, 2005 | 06:51 PM
someone answer me!!!!
Old Mar 2, 2005 | 02:07 AM
bump.
Old Mar 2, 2005 | 05:30 AM
Default Re: All motor lsvtec buildup (JIDUM_Undercover)
come on!!!
Old Mar 2, 2005 | 06:20 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
I don't remember if the rods were machined, but I used 8mm on my LS rods.
Old Mar 2, 2005 | 06:54 AM
I dont think u need to with 8 thats standard if im correct 9 is the bigger one. What about gaps and such on piston rings, and the procedure for bearing installation.
Old Mar 2, 2005 | 09:13 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (JIDUM_Undercover)
use 8mm arp rod bolts, stock replacement size, rings for a b16a, b18c, b18c5 are all the same and will work, as far as "clocking the rings" and installing the bearings, I would recomend buying a helms manual for the integra. I purchased the 98 service manual, and it was a great investment. It covers all the specs for the ls, gsr, and type r motor. Good luck with your build
Old Mar 2, 2005 | 12:04 PM
aight dude do i just go with the ls specs for everything?
Old Mar 2, 2005 | 12:49 PM
I bought ITR pistons and rings...worked for me .
Old Mar 2, 2005 | 01:00 PM
hurleyboarder21's Avatar
Default Re: (DAantagonist)
i just bought the rings that went with the piston set... napa rings own
remoer
Dec 1, 2008 08:14 AM
slow hatch
Oct 3, 2007 08:05 PM
turboteggsr
Jun 12, 2004 12:20 AM
MaxBoost
20
Jul 7, 2003 11:50 PM
cottagecreep
Feb 28, 2003 04:21 AM
