hondata s200 help!
Old Mar 1, 2005 | 05:44 PM
jdmlife's Avatar
Default hondata s200 help!
ok havent got my s200 installed yet. i have a CEL and vtec wont work. does the s200 have to power to over write CEL codes so vtec can work?
Old Mar 1, 2005 | 06:12 PM
B20TDC2's Avatar
Default Re: hondata s200 help! (jdmlife)
you can clear codes with s200 if vtec is not working there might be a bigger problem. what code are you throwing
Old Mar 1, 2005 | 06:27 PM
jdmlife's Avatar
Default Re: hondata s200 help! (B20TDC2)
im not for sure.. i just put itbs on.. tps is not 100% calibrated
Old Mar 2, 2005 | 04:34 AM
IN VTEC's Avatar
Short the diagnostic wire to ground and check the code. Fix the problem if possible.
The ROMeditor can disable certain kinds of error codes, like INJ circuit error (CEL16), o2 heater (CEL41), o2 closed-loop disable (CEL1), VTEC pressure check (CEL22?), etc., but it can't disable all of them.
2wheelhunter
Aug 15, 2006 08:11 AM
dornon13
Jun 9, 2005 03:01 AM
JDM-SHREK
Nov 8, 2004 07:36 PM
MayhemSi
Jul 11, 2003 02:50 PM
Rhetoric
Jan 2, 2002 01:10 AM
