Sway bar endlinks
I have a set of Energy suspension "sway bar end links" and would like to know where they would be most effective? Front or back? I have the Eibach Pro Kit with KYB's and plan on using my car for auto cross thiss year. Any input is greatly appreaciated.
Rick
Rick
the front and back endlinks are different DESIGN. they wouldnt be interchangeable because the designs are totally different.
theyre probably just for the front. (they dont make em for the rear)
Modified by Tyson at 5:49 PM 3/1/2005
Anything you do like that (rubber to polyurethane endlink bushings) will increase the effectiveness of the sway bar. Whether you will feel a subtle difference like that will depend on you the driver. You should be able to get back to back comparisions at an autocross, it doesn't take that long to change the front endlinks and you probably won't even need to jack up the car to do it.
The only thing is, as Tyson mentioned, those are front endlinks. Most people who autocross these cars aren't looking to increase the front roll stiffness. If everything else is kept the same, you're increasing the tendency for front end push/understeer.
jredhonn
Suspension & Brakes
Dec 26, 2007 05:34 PM
aw1234dude
38
Sep 26, 2004 09:48 AM
Mugen Hamster
20
Nov 20, 2003 03:59 PM
