Whats a cylinder sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">It is located in the distributor.
To change it, means changing out the entire distributor sub-assembly.</TD></TR></TABLE>
Cylinder Postition Sensor, IE TDC Sensor?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges »</TD></TR><TR><TD CLASS="quote">Cylinder Postition Sensor, IE TDC Sensor?????</TD></TR></TABLE>
Come again?
There are 3 sensors inside the dizzy: TDC, CYL, and CKP.
Come again?
Come again?
There are 3 sensors inside the dizzy: TDC, CYL, and CKP.</TD></TR></TABLE>
Guess I need to learn more about dizzy's
Come again?
DPFI, dual point, does only have two sensors inside the distributor - TDC and CKP.
MPFI, because its sequential, needs to know where the #1 CYL is - hence the additional sensor.
are the ecu codes the same for 92-2000? cause when i checked the code off the sticky it was for 92-96 civics. i dont own a honda so i wouldnt know. just trying to help out a friend. but the 92-96 civic ecu code book says code 9 is CYP- cylinder sensor...
quik89
Nov 30, 2003 06:43 PM
