Gas pedal is stuck in the morning.
Old Mar 1, 2005 | 12:08 PM
-pariah-'s Avatar
Default Gas pedal is stuck in the morning.
The first time I drive my car in the morning, the gas pedal is hard to initially push down. I have to tap it so it won't stick in the up position. It just started happening. Any thoughts?
2002 Accord
Old Mar 1, 2005 | 01:22 PM
JimBlake's Avatar
Default Re: Gas pedal is stuck in the morning. (-pariah-)
Crud in the throttlebody, where the throttle plate sits against the bore. Or maybe just a dirty cable??
Old Mar 1, 2005 | 05:40 PM
-pariah-'s Avatar
Default Re: Gas pedal is stuck in the morning. (JimBlake)
Thanks. I'll check it out.
Old Mar 4, 2005 | 11:58 AM
-pariah-'s Avatar
Not much crud. Any other thoughts?
Old Mar 4, 2005 | 12:54 PM
alotawatts's Avatar
Check the throttle cable just before it winds onto the TB. Is there adjustment bolts and a rubber cover/boot ? If so spray a silcone lube in the cover boot. Slide it back and forth a little to loosen the old lube/sh*t up inside.
Old Mar 4, 2005 | 04:25 PM
hondadude's Avatar
It doesn't take much crud to get the S.T.D. [sticky throttle disease] A soft bristle brush, some carb cleaner, hold the throttle open and spray and scrub. Then wipe out the junk and see how it works in the morning.
Old Mar 4, 2005 | 10:09 PM
iam7head's Avatar
Default Re: Gas pedal is stuck in the morning. (hondadude)
Let me guess, it's a f23a4 four cylinder?
they have a recall on that, i happens quite often especially the SE model.
so call up your dealer
Old Mar 5, 2005 | 09:49 AM
RMRf23's Avatar
Default Re: Gas pedal is stuck in the morning. (iam7head)
my mom has a 01` 4dr EX that was doing the same thing. The dealer took care of it for her. Call them up.
Old Mar 5, 2005 | 11:16 AM
-pariah-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">Let me guess, it's a f23a4 four cylinder?
so call up your dealer</TD></TR></TABLE>
Your right on the money. Thanks, I'll check into it..
Old Mar 5, 2005 | 01:23 PM
1-racer's Avatar
I would take some carb cleaner and spray it all over the spring and cable and then take wd40 and spray it down after that. You probally have dirt and grime in the spring
Squidwerd
Aug 15, 2013 01:30 AM
VietCloud7
May 6, 2008 04:46 PM
91da9ls
Jan 29, 2007 04:00 AM
mr poo
15
Jun 14, 2006 08:09 PM
95accordracer
Jan 11, 2003 07:43 AM
