Colder spark plug to help against detonation?
Old Jan 21, 2002 | 08:12 AM
HX_Guy's Avatar
Default Colder spark plug to help against detonation?
Im currently running the Bosch Platinums and at anything higher then 15 degrees it detonates (12:1 CR on 91 octane)...it also detonates bad at low RPMs in high gears, even on 15 degree base timing.
Should I try a colder running spark plug? Any suggestions?
Old Jan 21, 2002 | 08:15 AM
HX_Guy's Avatar
Default Re: Colder spark plug to help against detonation? (73rd 2000 ITR)
Yes...unless I dish out $5+ per gallon of unleaded 103 octane
Old Jan 21, 2002 | 08:24 AM
Big Phat R's Avatar
Default Re: Colder spark plug to help against detonation? (HX_Guy)
Up here in Canada - we are fortunate and can get 94 at the pump. I was running Denso Iridiums for about 6 months that were 1 temp range colder. I found that the car ran really rough when cold and stalled once in a while. These problems disappeared when I switched back to the original plugs. Maybe you should get a fuel pressure riser?
Old Jan 21, 2002 | 08:29 AM
HX_Guy's Avatar
Default Re: Colder spark plug to help against detonation? (Big Phat R)
It has plenty of fuel
I think Ill get the NGK BKR7E-N11...I was going to try them but couldnt find them in stock.
Old Jan 21, 2002 | 08:34 AM
Mike K's Avatar
Is your combustion chamber spot-faced?
Try running less base timing.
Also, the Skunk program is crazy on the timing maps.
Too bad you sold your Hondata. I would have sent you my program I did for my car this past weekend.
Old Jan 21, 2002 | 08:35 AM
HX_Guy's Avatar
Default Re: Colder spark plug to help against detonation? (Mike K)
No, the head is 100% stock, combustion chambers and all.
Im running the Mugen chip, didnt even try the Skunk2 program.
Any idea how the ignition maps on that are?
paul_573's Avatar
I'm running the NGK BKR7E-N11 in my GSR motor. No problems, had to order those as they weren't stocked.
Old Jan 21, 2002 | 08:40 AM
sgT's Avatar
sgT
cheap plugs = cheap performance.
Old Jan 21, 2002 | 08:42 AM
Mike K's Avatar
Default Re: Colder spark plug to help against detonation? (sgT)
Val, the Mugen and Skunk programs are the same.. I don't care what anyone says. Same .
I am running the PFR6G-13 plugs in my car.
You should have had your chambers matched.
Old Jan 21, 2002 | 08:44 AM
HX_Guy's Avatar
Heh, too bad non of the damn shops around here are skilled enought to do it, rememeber what happened to my B20 head?
Ill try some NGK Platinums next time..Ill order them today
Old Jan 21, 2002 | 08:45 AM
azn98R's Avatar
NGK BKR7E-N11 better than stocks? Which ones are the best? I am in Miami so I don't have to worry about cold weather, hehehe....
Old Jan 21, 2002 | 08:54 AM
sgT's Avatar
sgT
Default Re: Colder spark plug to help against detonation? (azn98R)
Best plugs = PFR6G-11 & PFR7G-11
Old Jan 21, 2002 | 08:55 AM
HX_Guy's Avatar
Hehe..are those the $15 per plug ones?
Old Jan 21, 2002 | 09:01 AM
azn98R's Avatar
I was so close to getting Spoon Iridiums, but I cancelled the order when I thought $140 for plugs....I don't think so
sgT's Avatar
sgT
pay extra for plugs? or pay extra to rebuild motor due to detonation damage?
Old Jan 21, 2002 | 09:26 AM
azn98R's Avatar
True....
Just not used to spending over 100 for plugs. PFR6G-11 & PFR7G-11 are better than stock, that's all I need to know.
Old Jan 21, 2002 | 09:27 AM
sgT's Avatar
sgT
PFR6G11 IS stock.
pfr7g11 is one colder. but i have no problems with using 6s.
as far as over 100 for plugs? these are 12 each.
walrus_07
Oct 25, 2011 11:16 AM
crashsvg
Engine Management and Tuning
Oct 14, 2011 09:26 AM
Tad
21
Oct 29, 2003 12:28 AM
Rah Rah
May 23, 2002 08:30 AM
