Motec Wideband
Old Mar 1, 2005 | 06:14 AM
Pootie's Avatar
Default Motec Wideband
Anybody know where to buy the wideband O2 that Motec uses in the PLM (besides from Motec)?
Old Mar 1, 2005 | 06:25 AM
tony1's Avatar
Default Re: Motec Wideband (Pootie)
We have them in stock.
Norwood Autocraft
972-722-2813
Tony
Old Mar 1, 2005 | 09:09 AM
Aggressive Racing's Avatar
Default Re: Motec Wideband (tony1)
tony1 how much do you sellem for,I usually get em from the Cadilac dealer for 165
Old Mar 1, 2005 | 10:17 AM
Suprdave's Avatar
I buy the VW Sensors and use the plug off my old sensor. 60 bones...
Old Mar 1, 2005 | 11:09 AM
buck02's Avatar
Default Re: Motec Wideband (Suprdave)
what is the gm part num for the sensore i work at dealer and can get them at cost let me know gm part num
Old Mar 1, 2005 | 01:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">I buy the VW Sensors and use the plug off my old sensor. 60 bones...</TD></TR></TABLE>
I heard thats the bast way,and more affordable
Old Mar 1, 2005 | 01:43 PM
Suprdave's Avatar
Default Re: Motec Wideband (aggressivemotorsports)
2003 Jetta GTI 1.8T Turbo
Front O2 Sensor
That's the one I usually get...If yu need the VW part #...Call Innovate, that's the exact sensor they use in their kits.
Old Mar 1, 2005 | 02:25 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">2003 Jetta GTI 1.8T Turbo
Front O2 Sensor
That's the one I usually get...If yu need the VW part #...Call Innovate, that's the exact sensor they use in their kits.</TD></TR></TABLE>
That's good to know...
Old Mar 1, 2005 | 07:41 PM
locash's Avatar
Hell, I could use a few Bosch spares for my Motec PLM, but I'd like it with the correct plug, and dont mind paying a few bucks more for it this way, what was the GM part number? I'm pretty sure the newer Saturn uses the same sensor with the correct plug as well..
Old Mar 1, 2005 | 07:42 PM
buck02's Avatar
Default Re: Motec Wideband (locash)
does anyone know what gm car specifically it comes on i need the plx type sensore and what car it comes on and were at the front bank1 front sensor or what
Old Mar 2, 2005 | 09:27 AM
Rtype16's Avatar
Default Re: Motec Wideband (buck02)
The best thing to do would be this. The sensor that the Motec PLM is the older version of the sensor. No longer used on newer vehicles Bosch has changed there style of connector on the sensor. The new sensor is more common a number of newer cars cavalier, G35, etc.... If you really wanted to and this is what I would suggest. AEM sells the connector kit to convert the old style to the new style end. Part number 35-2613 MSRP of $14.95 (you can probably find this cheaper no one sells for MSRP). Than you can buy the newer replacement sensors from a bunch of different cars. AEM part number is 30-2001 MSRP $86.94. This would be my suggestion. Hell if you have a shop and buy from AEM or buy from one of AEM's distributors it would be even cheaper.
Old Mar 2, 2005 | 07:53 PM
buck02's Avatar
Default Re: Motec Wideband (Rtype16)
the the new caviler has the correct o2 we need for like the plx m300 or the any of the widebands out there its the front sensore right the one before the cat
Old Mar 3, 2005 | 03:34 PM
motecnate's Avatar
If you look carefully there is a calibration resistor on both lambda sensors and the PLM requires a firmware upgrade in order to recognize it.
FYI send us your PLM and have the unit upgraded so it can use VW LSU 4.2. You cannot use the same resitor cal off a LSU 4.0 on a 4.2. I gurantee you that lambda values are wrong if you just lob off the connector.
The cost is $20.00 + return shipping if you send the unit to us.
Nate
Old Mar 4, 2005 | 08:37 AM
Suprdave's Avatar
Default Re: Motec Wideband (motecnate)
Yes they are slightly off...reads .2 AFR rich. I noticed along time ago and tune accordingly. I didn't know I could send in for new firmware. I'll definately be doing that? Who do I need to talk to about it If I call Motec West?
Old Mar 4, 2005 | 09:20 AM
When i called Motec west i spoke to,i believe his name was(George Clark)he was very helpful to talk to.
He was the one to help me convert mine from Lambda to A/F over the phone.
Old Mar 4, 2005 | 09:26 AM
bigTom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motecnate &raquo;</TD></TR><TR><TD CLASS="quote">If you look carefully there is a calibration resistor on both lambda sensors and the PLM requires a firmware upgrade in order to recognize it.
Nate </TD></TR></TABLE>
as far as the calibration resistors are concerned i have gotten mixed stories about if they are needed or not... can i eliminate it and change the plug outright? i know iv seen i done but id rather not screw up the plug on the motec plm... i wont just cut and splice it back on... i cant half *** it
Old Mar 4, 2005 | 01:46 PM
Rtype16's Avatar
Default Re: Motec Wideband (ek9t)
Sorry forgot to mention that little thing. Sorry Nate. Yeah you have to getyour PLM updated from Motec. Call Nate over there he will be more than happy to help you out. Than you can change the plug end for the newer sensors.
sky9
Dec 6, 2006 10:28 AM
b20vtecEK
Mar 30, 2005 01:04 PM
See Are X
Aug 22, 2004 11:17 AM
darylfiend11
Jun 27, 2004 01:20 PM
turbopanda
Apr 27, 2003 10:02 PM
