Which is Better: Block Guard or Girdle?!?!?
Old Mar 1, 2005 | 05:20 AM
jdm96dc2's Avatar
Default Which is Better: Block Guard or Girdle?!?!?
anyone have any input on which would help protech my b20 block at high rpms better? any help would be greatly appreciated...thanks!
Old Mar 1, 2005 | 06:54 AM
mmuller's Avatar
Mad Scientist
Default Re: Which is Better: Block Guard or Girdle?!?!? (jdizzle00)
none of the above.
girdle? mm if you do lots of high speed runs with lots of stress on the motor.
block guard..they suck
look into block posting if you want reiforcement on the sleeves and balance for high rpm stability
Old Mar 2, 2005 | 08:08 AM
civic-4-ges's Avatar
Default Re: Which is Better: Block Guard or Girdle?!?!? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
block guard..they suck</TD></TR></TABLE>
They do???
Old Mar 2, 2005 | 10:40 AM
NRN GT4's Avatar
Default Re: Which is Better: Block Guard or Girdle?!?!? (civic-4-ges)
With a B20 you will def want replace the rod bolts for sure this is even if you dont want to rev on a consitant basis.
The girdles are good to have if you have the cash but not always needed and sometime cause more damage then good(most of the time the installers mistake)
Block guards are a very controversial topic some say yes some say no. I know some people have ran them and liked and some that didnt like. Personally, I dont feel that a block guard does any good(my opinion) but it all depends on the intended application.
Old Mar 2, 2005 | 02:28 PM
PrettyLude's Avatar
the b20 walls are thin, put some sleeves in, not a blockguard
Old Mar 2, 2005 | 06:21 PM
FLOWZILLA's Avatar
Default Re: (PrettyLude)
a girdle relieves stress from the crank its nice to have but not necessary the block gaurd can cause more harm than good due to improper installation, the main reason they are popular because before we had many options like today that was it block gaurd or posting it , but now that sleeving has become an option block gaurds are not needed. the problem with block gaurds is that if installed uneven (like in most cases) it will throw the bore out of round to say the least.. soo with that being said save some money sleeve it and never look back... hope that help
Old Mar 2, 2005 | 06:55 PM
mmuller's Avatar
Mad Scientist
besides improper installation; blockguards inhibit cooling where you most need it and distort cyl. bores.
when the engine reaches operating temp. the block guard will expand causing deformation of the top of the sleeve.
Old Mar 3, 2005 | 02:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">besides improper installation; blockguards inhibit cooling where you most need it and distort cyl. bores.
Interesting....So the fact that the blockguard has more room for coolant to flow than the headgasket, still inhibits???
Distorts cylinders??? Everyone knows to get your bore/hone done AFTER the block guard is installed!!
Your sleeves are going to deform at operating temp anyways, might as well do it safely
Old Mar 3, 2005 | 05:35 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Interesting....So the fact that the blockguard has more room for coolant to flow than the headgasket, still inhibits???
?? more room? you are taking room away. from the top of the water jacket that is.
Your sleeves are going to deform at operating temp anyways, might as well do it safely</TD></TR></TABLE>
i was assuming honing after the block gueard is installed. but in order for the top of the cyl. not to distord would be to bore/hone with the top of the block at operating temperature since remember our sleeves are joint together in the middle and not free standing form eachother.
And the block guard would have to have equal clearance all around the cyl. wich, well is hard to do...
Old Mar 3, 2005 | 07:57 AM
It may be taking away from the waterjacket, but still not impeding coolant flow, just capacity
Old Mar 3, 2005 | 10:55 AM
sleepin91teg's Avatar
With a good tune you shouldnt need anything!
wesley_925
Jun 29, 2008 12:16 AM
jdm96dc2
Mar 1, 2005 07:17 AM
lemongreenhatch
Sep 27, 2004 02:01 PM
sPaRk'iT
Jan 30, 2004 10:45 AM
Aquafina
Nov 2, 2003 05:56 PM
