Anyone know where I can just get the iron part of the sleeves for a block??
Got a block that needs to be re-sleeved in two cylinders, anyone know where I can get the iron sleeve part to get put into the block by a shop??
The iron part is what gets replaced when it gets sleeved.
Whoever is doing the sleeving will do this for you.
If you're talking about the outer layer of aluminum on the OE sleeves, I'm not sure.
Yeah, i was trying to see if I could get the sleeves from Honda/Acura and then give them to the shop to install ...... I only need two of the iron linings, not the outer aluminum part.
Trying to figure out the cheapest way to do this ..... I got the block for free.
